D14 front wheel weight bolts
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: D14 front wheel weight bolts
    Posted: 14 Sep 2023 at 6:29pm
What kind of bolts do I need??
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 8:04pm
So I’m thinking these have a special head to fit in the slots of where the dish meets the rim?
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 8:10pm
223565 is part number. Square head with one side flush with bolt
Edited by Mikez - 14 Sep 2023 at 8:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 3:59am
Hey Mike thank you! My neighbor had these on his D17 II and I do remember they were an odd shaped bolt. Thank you!
                          Dana
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 8:19am
Dana, I made mine out of all-thread and flat stock. Might have an extra set around here if you can't find any closer to home.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 12:07pm
Hey Mike thanks. Are they 1/2 inch dia?
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 5:33pm
Also how long are these bolts ,anyone know? Thanks. Dana
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 7:31pm
I believe 1/2”. I’ll try to get dad to look. And I know we have old 1/2” square headed bolts here too. Can grind one side off. I’ll get on this tomorrow
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 8:22pm
Thanks Mike
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 7:32am
Dana, mine are 1/2-13x4".
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 5:30pm
Thanks! I’ll make them Mon am.
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 5:37pm
Any magical technique to get them mounted with tires on tractor🙀
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 6:32pm
Figures the square headed bolts I was thinking of are 3” and 4-1/2” long.
Here’s a real bolt. Measures 3-3/4” long.
Edited by Mikez - 16 Sep 2023 at 6:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 7:40pm
Wow theres a real oem!
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2023 at 5:26pm
I sat tire and rim between 2 milk crates and set weight onto rim, reached under and fed the ground off carriage bolts up through.
                          Dana
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2023 at 7:40pm
what happened to ( waiting until Monday morning???
To make your bolts???
Just kidding!
I know! It’s a New toy!
It cleans up Great!
Enjoy
DeWayne
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2023 at 5:27am
Well the nearby Amish machine shop does not work on Sundays , unlike me. If I didn’t work on Sundays I surely wouldn’t have 13K bales of hinquality hay in the barn! Anyways I used 4”:carriage bolts on Sunday morn😁
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2023 at 5:38am
I rolled the 14 out of the shop and took pics, then rolled in the 7030. HD antifreeze as per Dr Allis , engine oil and filter changes and new manual water temp gauge will be added. Then wash and wax. And windows cleaned. Then next is the 7040 for same fluid changes and also the radiator has to come out and be fixed as per the leak in August. Dr said loosen radiator cap to see if that helped. It surely did. Started last week with a new 55 gallon barrel of hd 15-40 diesel oil. It’ll be empty by tomorrow😫. Cheers and y’all be careful with fall harvest approaching!
                          Dana
