D-14 front end weights
Message Reverse Sort Order
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Topic: D-14 front end weights
    Posted: 03 May 2010 at 9:26am
Dave, just let them boys drive one of your tractors themselves, Then you can look at your tractors going down the road with you. lol
Don
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2010 at 6:50am
Eldon has the right idea, I can put a loader on front and fill it with grocerys to keep these Guys going for the day.  Dave.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 10:52pm
I thought all D14's came with a trip loader in place of the weights....
ALLIS EXPRESS!
This year:
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 10:32pm
Front wheel weights are shown in the D14 parts book as being the only weights offered for the front end by the factory.  Although I have never run a WD or WD45 much, I believe the comments about the 14 handling rear mounted implements better.  The D14 torque tube is a very heavy unit, as it is filled with Power Director and PTO gearing as well as the hydraulic pump. Along with the fact that the operator's position is ahead of the rear axle, it makes sense to me that the D14 would be better balanced despite the weight difference from the WD/WD45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 10:10pm
With 3 boys in the carryall, the front end is a little squirmy.  The way they put away the grocerys, I won't be able to keep it down for long.  Dave.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 8:41pm
I understand what Norm is talking about. Having no farming experience, but having owned both D-15/WD-45 the D-14/15 platform makes you feel lower and more grounded is the best I can describe. I miss my old 15', I'm gettin real close to the 175 now, I really like it's platform, heavily weighted, just like a tank.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 8:27pm
  we had d-14 an  1wd  1wd45 d-17  done all the planting with the 14  carried the planter better than the 45 or wd  same was for a 4row cult  have use it to believe
  do your checking  check your axle lines youin are sleeping   try it!!!!!
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 7:53pm
I'm intrigued by Norm's comment - according to the Data Book, D14 weighed 4,200# while the WD45 weighed almost 4,500#. So the D14's ability to carry more weight was something other than tractor weight!
WC, CA, D14, WD45
Jason(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jason(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 6:51pm
The D-14 never used the front slab weights. The frame is narrower than a d-15 or d-17. I don't remember exactly how much narrower, maybe 1 or 2 inches. You can put a weight bracket on a d-14, but you have to put spacers between the frame of tractor and the weight bracket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 10:53am
  the D-14 WILL CARRY MORE WEGHT ACCORDINGLY THAN A WD-WD45  FROM EXPERIENCE  WHEN FARMING   4 ROW CULT ,PLANTER ETC.  THE 14 IS NOT NEAR AS LITE  AS THE WD45 WAS
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 9:51am
Never seen any for a 14.  I think they are narrower than the other tractors you listed, so the weights would not fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 11:15pm
Did the D-14's use the front slab weights that the WD,WD45, D-15,D-17 and D-19 used?
I was looking at Tony Carbaugh's web site and the weight brackets are not listed for the D-14's.   Thanks, Dave.
