D14 Final drive spacer |
bozrae ![]() Bronze Level ![]() ![]() Joined: 02 Jul 2012 Location: Michigan Points: 165 |
![]() ![]() ![]() ![]() ![]() Posted: 24 May 2021 at 5:41am |
Bought a D14 last fall and didn't notice until recently that it had spacers on the final drives. I looked this up in the online Agco Parts book and it does show them.
It says they are for 63" to 97" wheel tread. I've never seen these, does anyone know what implement they would be used for and how common are they? |
D15D, D17G, 170G, 175D, and two 5050FWA
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Here is a set I will be installing on a D-15 series 2 diesel along with a single front wheel for a forum member that I am rebuilding tractor for. ,he can jump in and fill u in on what he's doing it for.
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 83515 |
Fred, is there an extension for the top shaft, or is it one complete DIFFERENT part from the standard D15 ?
Top shaft Is longer
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 2812 |
I was also wondering about the pinion shaft . Thanks
Were these used if you wanted a mounted corn picker?
Richardmo ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Rolla mo. Points: 1746 |
They were used on the high crops D 14 and 15.
How wide are the spacers? Edited by Richardmo - 25 May 2021 at 10:30am |
The spacers are 4-5/16" wide.
The reason I thought they might be for a mounted corn picker is because is has what looks to be a factor screen enclosure on the air intake.
6 1/2 on the axle's I am working on
mruhlig77 ![]() Orange Level ![]() Joined: 19 Aug 2014 Location: central Indiana Points: 583 |
In your AGCO book..do the spacers imply a high-crop or a single front end????I would bet on the corn picker or vegetables....Mark
The high crops have the wider one.
Also check the parts book calls out for a different axle for the picker so maybe that is what that is for. |
Found my own D-15 book ....appears there were also 3 widths of wide front ends....did not list applications of the wider rear....Mark
Here is some info from the online book. They have different part numbers for pinion shafts but only one part number for a RH and LH side spacer.
