D14 Engine Parts Needed
Dan (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan (MI) Quote  Post ReplyReply Direct Link To This Post Topic: D14 Engine Parts Needed
    Posted: 21 Jan 2010 at 4:50pm
      Okay guys, this is it... This should be my last cry for help!  (on this tractor anyway)My engine is totally rebuilt, and all I have to do is adjust my valves and bolt the cover on.  (or so I thought)  Upon putting the torque wrench to the nuts on my Rocker Arm Shaft Supports, (#227627) I found that 2 of the 4 are CRACKED!!!   I'd like to replace all 4 with some known good ones.  I believe they were originally "over-torqued" at one point in it's prior life...  Does anybody have a set they would part with?  Is there any new ones out there?  My D14 is a 1957 w/ 149 engine...  I sure would appreciate the help.  I'm so very close!!!
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 5:21pm
Dan
As i understand, that is common on the 14 and 15.  I had two broken ones on my D 15 II.  I got two used ones from sandy lake.  they had new ones also.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 5:24pm
I have opened up engines with the rocker shaft stands welded , they seemed to be holding up well.
WEL(TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WEL(TN) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 5:25pm
Usually those break when you assemble the rocker arm shaft without backing off the rocker adjusting screws. I think I have two of them. I will look this evening.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 5:58pm
yes make sure the pushrods are down in the lifter. and the rockers are all backed off . then make sure each stand is down on the pedastal before putting the wrench to the nut. If they aint they will break and are not forgiving.
MBwcenll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcenll Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 6:29pm
I got one from AC about 2 years ago; $70.00, ouch!  For sure find a used one and I almost think one could machine one from square stock.  The replacement from AC was square.
