D-12
Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed Quote  Post ReplyReply Direct Link To This Post Topic: D-12
    Posted: 30 Nov 2009 at 11:02am
Did the d-12's have power steering?
Thanks!
TerryMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TerryMN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 11:52am
For the most part no. Some, mostly industrial tractors were sold with power assist steering like what a small Ford tractor had. They still had a steering gear box. This option could be factory ordered or dealer installed. The clutch pedal had to be cut and moved to make room for the cylinder/valve assembly. Power Assist steering is somewhat rare to find on a D-10/D-12. It also got in the road of the front mount cultivator so that is the main reason why hardly any ag tractors had it installed. I have never driven one with the power assist steering I am sure it helps. You see it most offten on a tractor that has/had a loader and the heavy duty front axle.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 11:55am
Yes, available as an option labeled as a non agriculture if you will because the steering ram and link would interfere with front mounted implements such as a front cultivator or other.
If you have one of these now, keep it.
Some customers chose to install anyway.
The I40 and I400 use a hydrastatic power steering set up where the ram is mounted to the front axle, much the same as the bigger tractors and was a neat installation on the I40-I400.
