D-10 series III lift arms won't lower
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: D-10 series III lift arms won't lower
    Posted: 10 Dec 2024 at 11:44am
So after 3 yrs finally got son's D-10 series III rebuild complete, first start last week. Seems great except lift arms raise by themselves every time when started. We had no hyd. problems at all before the rebuild , operators manual is 4 hrs. away at his house.  Cant' figure out why sitting that long would cause this , any help appreciated, keith ,so va.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 3:24pm
Likely the TB linkage is amuck. It's the 2 little levers by your right hip as seated in the OP. I can't exactly tell you which way to position them, you will have to wiggle and test...Wink
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 3:26pm
Traction booster valve is stuck
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 3:27pm
Or the linkage that works it
1984 80780
1957 D14
616 tractor
Ltcmikesr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ltcmikesr Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2024 at 12:07pm
Just get a om pdf on line. What i do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2024 at 5:40pm
Ive helped overcome that problem on at least 4 different tractors in the last couple years. Theres a spool in the hydraulic valve that does not have a hand operated lever attached to it. In front of that spool is a lever on a pivot that is attached to the linkage from traction booster and position control. On 2 tractors that pivot was froze up. On my D17 series 4 the sping on the back or the spool was binding and needed attention. If you cant figure it out ill give you my phone # and ill try to talk you thru it. Ill guve it to you anyway. Donald Matthews 910 824 8856
Leave a message. I dont answer calls i dont recognize
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2024 at 11:50pm
Thanks, I seem to have fiddled with it enough to make it work. Thanks keith so va
