d-10 series 3 battery replacement
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: d-10 series 3 battery replacement
    Posted: 06 Sep 2020 at 3:48pm
what battery do yall like , with lots of cranking amps , that will fit in the battery box on a d-10 series 3  ????   thanks keith so. va.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2020 at 5:56pm
You're going to get as many different battery sizes as you get answers here.  I use a group 22 (sometimes it's called a 522 or 22 for a Ford) There are two batteries that fall into the Group 22 size for some reason. The one I'm talking about is just about the same physical size as a group 1 - 6Volt battery and fills up the box on all the little ACs great. Many also will use a group 26 (just be sure that you get one with the  +&- terminals oriented the correct way) ,which is shorter and needs a piece of plywood under it to keep the cables from rubbing in the battery box edges.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2020 at 7:11pm
thanks paul, this is my sons tractor......  i realized while working on it i gave him the best one here!
