D-10 s III
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Topic: D-10 s III
    Posted: 20 Sep 2010 at 1:43pm
My D-10 has a 12 volt system on it, the generator was changed to a 1 wire  alternator with a 3 pole ignition switch. The switch was giving problems so I changed it to a 2 pole switch and added a diode. It bleeds about 2.25 volts, draining about .04 volts a day from the battery, Why?
Dusty
pineyjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pineyjd Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 3:25am
Are your gauges shutting off
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 6:35am
Yes. The diode is part of the plug that plugs the wire into the alternator.  If I unplug it the 2.25 volt drain goes away. Or if I pull the alternator wire off the ignition switch the 2.25 volt drain stops.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 7:06am
I took my meter and the new harness back in to where I got it. They got another one off the shelf. They both tested the same. I went to an auto parts and got another alternator, put it on, still had the drain.
I took the alternator back.
Dusty
This page was generated in 0.050 seconds.
