D10, hydraulics won't go down...
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Topic: D10, hydraulics won't go down...
    Posted: 20 Jun 2023 at 12:36pm
My Dad lives nearly 400 miles away so I can't give him a hand for a while myself. The 3 point hitch won't come down and I know checking the linkage adjustment is number one but if someone has had this on their D10 or D12, I'd be interesting to hear how it was solved. It worked fine last year so this is from sitting over winter. My Dad is going on 90 this year with failing eyesight, otherwise very mechanically inclined. If I can give him pointers over the phone I will.
Thanks for your input.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2023 at 8:18pm
My nephew bought a D10
The arm that presses the spool for traction booster was siezed on the pin. It was pushed in enough to hold the lift up. We soaked it in penetrant and tapped it back and forth untill it freed up. Worked great after that
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2023 at 8:37pm
The arm that presses the spool for traction booster was seized on the pin. It was pushed in enough to hold the lift up. We soaked it in penetrant and tapped it back and forth until it freed up. Worked great after that
Thank you, I will pass this valuable tip onto my Dad, it may just be the case with his D10 as well.
This page was generated in 0.134 seconds.
