D10 - D12 parts wanted
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: D10 - D12 parts wanted
    Posted: 15 Aug 2010 at 10:09pm
Looking for the hyd pump intake hose for series II or  III. Are the rubber dampners available for the PTO? Thanks Tracy Martin
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 8:41am
Tracy, my local AGCO dealer did a nation wide check for the intake hose for my D-10 seres III, there were none available.
I went to a local NAPA dealer they could get a hose that was similar. My hose had a large split in it. I got a piece of shrink tubing for electrical joints. I also used some Scotch Coat which is a liquid used for water proofing electrical joints. I coated my split hose with the Scotch Coat then put the shrink on and shrink it then applied another coat of Scotch Coat.
It's the same story on the dampers.
I have 1 in like new condition.    I WILL NOT PART WITH IT.
I made some out of neoprene. I can make some more.
Dusty
Edited by Dusty MI - 16 Aug 2010 at 8:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 8:53am
Dusty, Thanks for your info. I sent you a PM also. Tracy Martin
Bob in King NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob in King NC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 9:22am
Tracy. if its the hose I'm thinking of. I go to local hyd dealer and get a piece of hyd hose and cut to correct length ,3/4 the best I remember and they sell spring that goes inside to keep from kinking. I have replaced 2 like this and have had no trouble over the past 7 or 8 years. My 2 cents, Bobby in King, NC.
