D.Y.O. tire repair
BuckSkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2025 at 12:57pm
Originally posted by Ray54 Ray54 wrote:
super cheap used airplane tires
Growing up in a huge tire shop in farm country, I got to learn a lot about those used airplane tires.
On an airplane, they are on those wheels that have two halves that bolt together; they were never meant to be on a single-piece implement wheel.
The huge downfall to them that many fail to recognize and understand is the tire bead is much thicker than the bead surface on a standard wheel; therefore, most of that huge unforgiving sharp-edged bead is sticking way out over the wheel's bead shoulder; perfectly placed to play havoc with a tissue-thin agricultural tube.
If you are going to use airplane tires, there are places that sell them already mounted on a wheel === buy from them, wheel and all, and buy them TUBELESS --- then, before ever using them, take them somewhere that knows what they are doing and have them foam-filled.
Mounted tubeless and foam-filled, they will wear out the equipment they are on and the next replacement piece of equipment as well.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2025 at 8:09am
Originally posted by BuckSkin BuckSkin wrote:
If you are going to use airplane tires...
...take them somewhere that knows what they are doing and have them foam-filled...
...they will wear out the equipment they are on and the next replacement piece of equipment as well.
THE Truth.  They will be impervious to absolutely positively everything but sunlight and gravity... and you'll get every penny's worth out of that foam investment.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2025 at 8:54am
I remember my dad buying a set of mounted airplane tires for the E Gleaner combine one very wet year back in the 60’s. He then added chains to get the corn out. He later said he’d been better off leaving it until it froze as he tore up more muding it out than he would have just waiting, of course, sitting around waiting isn’t something farmers come by naturally.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2025 at 9:20am
My grandad had a LeTourneau earthmover that we pulled behind a IH TD24. It used bomber tires(can't recall which one) that if I remember right were 120 ply. For a long time there was a warehouse at the local closed airbase that had a stock of them, but they would have to go to the tire shop that in turn would send them off to have the bore shaved so they would fit the wheels. Definitely heavier tires than ag use. Not sure I would want them on something like a baler or combine, the tire is the only suspension it has so you want a little give. Probably be okay on tillage equipment though.
Ted
