Cylinder head studs
Beinepw#69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beinepw#69 Quote  Post ReplyReply Direct Link To This Post Topic: Cylinder head studs
    Posted: 13 Nov 2020 at 12:34pm
Who sells quality cylinder head studs for a WC engine? It is the older engine with 12 studs. Fine thread on top coarse on bottom. Eight are 1/2”x 4-3/8” and four are 1/2”x 5”. Mine show some wear so I’m concerned about stretched threads and how that affects torque. Or do you guys just reuse the originals? Opinions please. Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2020 at 5:59pm
If you are concerned with studs stretching at the threads, the simple check is to take the stud in question, and thread the appropriate nut on each section of thread.  If the threads are stretched, the nut won't go any further than where the stretching starts.  For overall length, you can check with a machinist's ruler, or a pair of calipers. Not building a manned rocket here, so its OK to re-use.  JMHOWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beinepw#69 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2020 at 2:29pm
Thank you. I’ll reuse. I just found out new studs from Agco are almost 200.00 bucks.
