Cutting Tooth/Edge
Boomer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boomer Quote  Post ReplyReply Direct Link To This Post Topic: Cutting Tooth/Edge
    Posted: 07 Apr 2010 at 10:54am
Have a WC Speed Patrol, and the cutting tooth/edge for the blade is marginal. One side is worn more than the other by almost one and a half inch. Is there a place to get another set? From my measurements they appear to be the same as the Onyx snap coupler blades. Where does people get the replacements for the snap coupler blade?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2010 at 12:34pm
If I remember right someone mention a Caterpillar part number that matches up with the oxnard blade.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2010 at 2:26pm
Cutting edges have a  standard hole pattern.  They come in 6, 7, 8 ft lenghts,  any construction machy dealer espicially if they sell motor graders should be able to hook you up.  Just know the length you need.   HTH
Bill (E.C.MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill (E.C.MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 3:57pm
Boomer,
The best and most reasonable source we have found for cutting edges, teeth, etc. (plus undercarriage parts and that sort of thing) is Cohn in Union, MO.  Try emailing our salesman Rick at rfreund@scohn.com or calling 800-351-2646
A-C's currently on the farm: B, CA, 2 D-17 D's, One Eighty, ass't implements.
Ron(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 9:34pm
Ziegler Equipment is a CAT dealer in Minneapolis where I got a replacement cutting edge for mine Oxnard blade. Part number is 7T-1633 (6 foot). Their phone number is 800-352-2812. There is another one in Altoona, Ia...phone #800-342-7002. Mine cost just over $40.00 a couple years ago.
Good luck,
Ron
