Crankshaft end play
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: Crankshaft end play
    Posted: 01 Jan 2020 at 1:15pm
How is the crankshaft end play adjusted on a BE116 engine?  Thanks, Tim
Dick L View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 2:10pm
Moving the crankshaft gear in. This is done by grinding the stop back. You need to make sure the inside edge of the main journal is smooth or it will eat up the flange of the thrust shell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 3:05pm
Can the crankshaft gear be removed with a puller or does it press off?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 3:36pm
It will come off with a puller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 4:13pm
Thanks for the replies DickL.
This page was generated in 0.093 seconds.
