Couple electrolysis questions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2010 at 8:18am
Tom, It is best if you can get a large surface area of the part facing the largest surface of the anode. Hanging the part also makes it easier to rotate to get the "dirty" side to face the anode.
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2010 at 8:43am
Thanks Chuck and Lou.
Having the part hang will be impractical for some of these parts so I am willing to have slower clean rate, just want to be sure it will still work.  Dont mind flipping and repositioning the part...
jjrosty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjrosty Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2010 at 8:53am
THe same guy that is cleaning the old wood machines also told me "Black to the Bailey" as in planes.  so the black always goes to what your cleaning.
 I didn't think AC current would work?
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2010 at 10:37am
I have not tried this yet but would like to. Is the part to be cleaned the positive or negative from the charger?
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2010 at 12:55pm
Neg to the part!!  I use a 250 gallon tote with the top cut out of it.
Boomer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boomer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2010 at 2:11pm
Has anybody tried it on a much larger scale. Like a whole body of a military jeep? What happens if there is bondo on the metal? How quick do you paint after use this method?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boomer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2010 at 2:12pm
What happens if you have bronze bushings?
Lance/SC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lance/SC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2010 at 7:13pm
Rawleigh, what do you use for anodes and what how far apart are they?  Got any Pics?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 11:16am
I am using some old metal shelving.  I used four at a time, one on each side.  I made jumpers from wire and battery clips to string them together.  I put a cinder block in the bottom to keep the part up off the floor.
I have heard of a person digging a pit and lining it with plastic to do trailer frames.  They used a DC welder for that job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 11:57am
Ok I started mine around 5:30 PM last night.
Used a 50 gal ruubermaid plastic tank waterer.
Used lye instead of washing soda...
For sacrificial anodes I bracketed the allcrop 60 piece with two MF plow landsides ..(with pleasure heheh)
Rested part on bottom of tank, no "hanging" I believe the plastic serves as an insulator from the other side of the equation.
Seems to work great...can hear the fizzing crazy like an just opened can of soda!
12 hours later is still fizzing; working on the rust...
Here is a formula I found that supposedly works even better:
Sodium Carbonate (washing soda) 75 grams/liter 10 0unces/U.S. gal.
Sodium Hydroxide (lye)__________12.5__________1.7
Trisodium Phosphate (TSP)_______25___________3.3
Sodium Silicate (water-glass)_____12.5__________1.7
Lucky for me I have a gallon of water glass laying around...(doesnt everyone?)
Will have to try this formula some time
Edited by TomYaz - 20 Sep 2010 at 11:59am
clovis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clovis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 4:44am
This has been a great thread...I've always wanted to try this method...thanks for the great posts everyone.
This page was generated in 0.095 seconds.
