Correct Clutch? Pic
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: Correct Clutch? Pic
    Posted: 26 Jan 2019 at 6:10pm
This is the clutch from that d-17 im working on. Measures bout 11in.   Is this 4-tab unit original & should I replace with a full circle of friction?? What do you use? thanks  Keith
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 6:33pm
I would say it’s original style. My 190XT had a 4 puck clutch. I did upgrade it to a 6 puck when I replaced it. D-17 owners on here will confirm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 7:19pm
Not original for a 1958 model D-17. That is what us old guys would call a One-Seventy clutch.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 11:09pm
With that type clutch, regrind flywheel and new pressure plate with new clutch. MACK
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2019 at 7:24am
That 4 pad clutch disc is for the D17 Series IV, originally...the spring cage side is the side that goes towards the pressure plate and the other side should have a longer hub protrusion that goes towards the flywheel. The reason the hub is short as you see in the pic is, because it has to be to clear the PTO hub in the cover. I've seen woven material on them, 4 pads, 6 pads and even feramic, which is very high priced. Depends on what you're using the tractor for, as to what material you should use.   Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2019 at 6:49pm
...and the woven wears the surfaces the least. Everyone has their opinion as to which is best.
