Corn production well off
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Corn production well off
    Posted: 30 Aug 2025 at 10:03am
Do not know of other areas but not seeing any reality of good in corn here. A few friends and contacts been pulling sample ears as stalks dry down, silks are mostly dried up, a few never pollinated and remain white with the stalk dead, shucked ears tell the true story.
For four counties around us ears are 1/2 -2/3 filled out, kernels are small and already deep dimpled, one sample tested at 27% moisture where estimations on fields that generated 210-240 b/a just a few years ago MIGHT make 150 this go, as well will be docked for small grain size and poor grade outs. Several are considering letting beef onto the fields as a feed out as will not regain the costs to harvest where insurance will not pay anything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 10:09am
You know ,, I listen to the Big 550 in the morning and they have an hour segment of Ag news, the big Farm tour was a couple weeks ago and they reported Illinois corn was very disappointing, looked good on the outside but kinda alot like you described Dave,,
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 11:22am
Our area observed 10.7” of rains in the month of July alone (July 6-20th) !!
What does that mean? If your corn pollinated towards the earlier timing (end of June & up til July 6th), it probably did ok & may exhibit good kernel development?
But if it pollinated during that heavy rainy period, lots of pollen grains could have been washed out of tassel &/or washed off ear silks, thus leading to No or very poor kernel development.
Corn tassels usually only shed pollen from 10~12am til 6pm? each day.
And good Viable pollen only lives about 12 hours? Also if your area experienced a drought prior to & during pollination, dry/hotter air temps could damage pollen production within the tassel, rendering it sterile? If so, any amount being shed is pointless.
To further complicate, ear silks are made up of 90% water. So any drought conditions could also limit silk growth.
IF,,, a field has no or reduced soil compaction that could enable good deep (5-8’?) corn root growth? Then, healthier plant’s roots may be tapped into lower ground water which may enable normal silk growth even during a drought?
Edited by AC7060IL - 30 Aug 2025 at 11:47am
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 12:57pm
Will be interested to follow along and see if the USDA prediction of 188.8 bu per acre(nationwide) is accurate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 2:39pm
planted BEANS here this year... First time in about 8 years..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 3:39pm
Now the Beans here, standing Tall, nice bushiness, loads of Pods.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 6:30pm
Around here too , but the $$$$ are low,,,
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2025 at 1:44am
Sunday morning (8/31/25) farm talk show had a short clip about "corn rust" and "tar spot" damages in some midwest corn fields. Causes early dry down of ears/plants. IF you have both in a field it can really hurt yield in what a few weeks ago was a really good field of corn.
dr p View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 7:06pm
Everything that could have gone wrong with early corn happened around here. Too much rain, then no rain at fill. And tassel disease with a little tar spot on top. The late corn (after 20june) looks better but if we get an early frost, it doomed. I have been growing more bmr sudan sorghum for silage. A little less yield but a lot less imputs. I add some dried beet pulp at the blower if its too wet. With corn at 4 dollars a bushel and max yield here at 150 bushels per acre, i think long and hard about just buying feed
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2025 at 7:18pm
Seems like a lot of the hybrid/GMO seed supply was geared for drought and then we get a lot of rain...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 2:39am
Best laid plans then nature steps up to bat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 12:03pm
This was a Ear furnished as Local was inspecting it, knows is Junk.
Is one of my Work truck tools, a Stanley 1/2" Wrench.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 10:37pm
Co-op manager in bear camp with us says that is quite common. this along with a few other maladies. He believes the yields will be much lower than predicted
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 6:40am
My crops all look pretty good. Some wind damage in the corn from July.
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 12:36pm
I'm in an area of irrigated specialty crops and farm small fields the bto guys don't want. My corn will probably make 125 and the beans 35-40. Good corn for me is 150 and beans 40. My ground is pretty sandy with some clay mixed in but nowhere enough. Also have some gravely hills to go with some beach sand. I've had around 3" of rain since pollination and we've had more 90 degree days than usual. I hope you all have a safe and successful harvest.
Part time farming with a 1980 7060 and 1984 F3 hydro.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2025 at 5:22pm
Will soon know as Harvest in Full Swing now.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 2:21pm
The rain will probably start also
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2025 at 7:44pm
There is a couple ongoing discussions over on LinkedIn, regarding the commodities prices going into harvest. General consensus is #2 yellow corn will average $3.90 per bu, with the average farmer ‘losing’ .85 cents per bushel. If my Jethro Bodine rithmatic is correct, that’s puts the average production cost per bushel of corn at $4.75+/-, this is insane.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 21 hours 40 minutes ago at 8:06am
Carrying onward, production estimate is 16.7 billion bushels. Losing $.85 per bushel, collectively $14.195 billion lost.
Yeah something doesn’t add up. I don’t think farmers are quite that big of idiots.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 12 minutes ago at 1:34am
New bigger ?better? Machines at a cost, to plant/harvest more high dollar purchased or leased ground, of crops that make little money yet are deemed as THE crops to grow. And who determined the US farmer needed to do ONLY wheat beans corn rotations? Then WHY?
