CONVERTING A D17 GAS TO A 433T
HillBilly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HillBilly Quote  Post ReplyReply Direct Link To This Post Topic: CONVERTING A D17 GAS TO A 433T
    Posted: 05 Feb 2026 at 11:21am
GOOD AFTERNOON YA'LL.
I CURRENTLY HAVE A 1961 D17 WITH A BUSTED NOT WORTH REPAIRING G226. I ALSO HAVE THREE F2 GLEANERS WITH 433T ENGINES IN THEM. I WAS WONDERING IF ANY OF YA'LL HAVE EVER STUCK A 433T INPLACE OF A GAS BURNER IN A D17? IF SO HOW MUCH TROUBLE WAS IT TO SWITCH OUT, AND HOW MANY MODIFICATIONS DID YOU HAVE TO DO TO MAKE IT WORK. ALSO IF YOU HAVE ANY PICTURES I WOULD GREATLY APPRECIATED. I DO NOT WANT TO PUT THIS TRACTOR BACK IN THE PASTURE, IT HAS TOO MANY MEMORIES.
Hillbillys lovin in the hay!!
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2026 at 1:59pm
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2026 at 3:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HillBilly Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2026 at 3:37pm
THANK YOU FOR THE INFO. LOOKS LIKE I AM GOING TO BE PULLING A ENGINE OUT OF A GLEANER F2.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2026 at 4:30pm
https://youtu.be/r_HCmrJiW4g?feature=shared
You have a spate 433 or two you would be interested im selling?
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2026 at 4:38pm
…next in line if you have one more
Edited by Gatz in NE - 05 Feb 2026 at 4:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HillBilly Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2026 at 6:31am
I HAVE ONE THAT CAME OFF A FIRE DAMAGE DEAL, AND ENGINE IS NOT STUCK. THE OTHER ONE IS A COMBINE THAT IS STUCK FROM A BLOWED HEAD GASKET, AND THE ORIGINIAL OWNER LETTING THE UNIT SIT. THE OTHER TWO ARE ACTUALLY ON FUNCTIONING MACHINES. YA'LL KNOW I AM IN VIRGINIA. DONT GET ME WRONG WHAT ARE THOSE ENGINES SELLING FOR?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HillBilly Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2026 at 6:39am
I WILL ALSO THROW THIS OUT THERE. THE ENGINES IN THE TWO RUNNING MACHINES HAVE ANY WHERE FROM 1,500 TO 2,000 ON THE ENGINES, AND THE HOUR METERS STILL FUNCTION.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2026 at 7:43am
If they start and run, they are worth quite a bit more in my estimation. These engines are 40 years old and the injection pumps oft times need $1,000 bucks spent on them to make them even run. I had one that the turbocharger was stuck and wouldn't turn. That would nix the deal for me as that would be an XXXpensive part.
Edited by DrAllis - 06 Feb 2026 at 8:15am
Post Options Post Options   Thanks (0) Thanks(0)   Quote HillBilly Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2026 at 9:48am
YEAH I HAVE TWO COMPLETE RUNNING UNITS THAT RUN GREAT, AND DO NOT SMOKE NOT UNLESS UNDER A LOAD. NO WET EXHAUST MANIFOLDS FROM LEAKING INJECTORS. THEY ARE SWWET RUNNING ENGINES.
VaAllis1990 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VaAllis1990 Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 24 minutes ago at 8:55am
Hillbilly,
Sorry I haven’t called you back . Got your message. I have a Gleaner E 226 I may would let go. I’ll call you here in the next day or so
