CONVERTING A D17 GAS TO A 433T |
HillBilly
Joined: 13 Nov 2012 Location: Farnham, VA Points: 23 |
Topic: CONVERTING A D17 GAS TO A 433TPosted: Yesterday at 11:21am |
GOOD AFTERNOON YA'LL.
I CURRENTLY HAVE A 1961 D17 WITH A BUSTED NOT WORTH REPAIRING G226. I ALSO HAVE THREE F2 GLEANERS WITH 433T ENGINES IN THEM. I WAS WONDERING IF ANY OF YA'LL HAVE EVER STUCK A 433T INPLACE OF A GAS BURNER IN A D17? IF SO HOW MUCH TROUBLE WAS IT TO SWITCH OUT, AND HOW MANY MODIFICATIONS DID YOU HAVE TO DO TO MAKE IT WORK. ALSO IF YOU HAVE ANY PICTURES I WOULD GREATLY APPRECIATED. I DO NOT WANT TO PUT THIS TRACTOR BACK IN THE PASTURE, IT HAS TOO MANY MEMORIES.
Hillbillys lovin in the hay!!
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5146 |
Posted: Yesterday at 1:59pm |
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1877 |
Posted: 23 hours 20 minutes ago at 3:05pm |
HillBilly
Posted: 22 hours 48 minutes ago at 3:37pm |
THANK YOU FOR THE INFO. LOOKS LIKE I AM GOING TO BE PULLING A ENGINE OUT OF A GLEANER F2.
coggonobrien
Posted: 21 hours 55 minutes ago at 4:30pm |
https://youtu.be/r_HCmrJiW4g?feature=shared
You have a spate 433 or two you would be interested im selling? |
Gatz in NE
Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1064 |
Posted: 21 hours 47 minutes ago at 4:38pm |
…next in line if you have one more
Edited by Gatz in NE - 21 hours 47 minutes ago at 4:38pm |
HillBilly
Posted: 7 hours 54 minutes ago at 6:31am |
I HAVE ONE THAT CAME OFF A FIRE DAMAGE DEAL, AND ENGINE IS NOT STUCK. THE OTHER ONE IS A COMBINE THAT IS STUCK FROM A BLOWED HEAD GASKET, AND THE ORIGINIAL OWNER LETTING THE UNIT SIT. THE OTHER TWO ARE ACTUALLY ON FUNCTIONING MACHINES. YA'LL KNOW I AM IN VIRGINIA. DONT GET ME WRONG WHAT ARE THOSE ENGINES SELLING FOR?
HillBilly
Posted: 7 hours 46 minutes ago at 6:39am |
I WILL ALSO THROW THIS OUT THERE. THE ENGINES IN THE TWO RUNNING MACHINES HAVE ANY WHERE FROM 1,500 TO 2,000 ON THE ENGINES, AND THE HOUR METERS STILL FUNCTION.
Posted: 6 hours 42 minutes ago at 7:43am |
If they start and run, they are worth quite a bit more in my estimation. These engines are 40 years old and the injection pumps oft times need $1,000 bucks spent on them to make them even run. I had one that the turbocharger was stuck and wouldn't turn. That would nix the deal for me as that would be an XXXpensive part.
Edited by DrAllis - 6 hours 10 minutes ago at 8:15am |
HillBilly
Posted: 4 hours 37 minutes ago at 9:48am |
YEAH I HAVE TWO COMPLETE RUNNING UNITS THAT RUN GREAT, AND DO NOT SMOKE NOT UNLESS UNDER A LOAD. NO WET EXHAUST MANIFOLDS FROM LEAKING INJECTORS. THEY ARE SWWET RUNNING ENGINES.
