Contents of D-17 Brake Housing
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Topic: Contents of D-17 Brake Housing
    Posted: 29 Jun 2010 at 8:00am
I disaasembled the RH brake on my D-17 yesterday.
The good news, the pin came out easily by simply clamping it with the "Vice-Grips" and
twisting it back and forth as I pulled on it.
Maybe the D-17 pins are less troublesome than the WDs and WD-45s?
As is typical, there was a large mouse nest in there.
I'm glad I discovered this now rather than later when it might have caught on fire like an experience I had a few years ago with my WD-45.
EricTn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricTn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 8:35am
I have had bumble bees nest in the RH brake housing on a 185. I found out the hard way. Bees got me three time before I figured out the bees werent every where, they were just every where I went on the tractor.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 11:48am
I can't WAIT to get into the brakes on my WD45, G and CA - all need attention! I'm suspecting that there are some fairly spectacular nests in some of those brake housings!
WC, CA, D14, WD45
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 12:22pm
I probably pulled that much out of the torque tube on my D14 when I changed the ring gear.  There were a couple young ones still hanging around when I did that.  Sure are cute little fellars.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 3:24pm
A couple of years ago when I got out my WD-45 for the first time in the spring I could not steer it. Turns out the prior owner had removed the hand crank shaft from the pedestal and mice had built a very large "condominium" in there. It took me a few hours to fish all of that stuff out thru the crank hole.
Needless to say, I installed corks in those holes after that incident.
