Concrete ??
 Post Reply Post Reply Page  <123
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2022 at 11:02am
AH only ONE INDIVIDUAL so far seems to know about Sugar .
Fantastic add for cleaning tools when done or for that emergency use if .
instructor for one class was Building Inspector for suburb city to MPLS . said he kicked a couple contractors off the jobs when he found sugar hidden near pour site , not in cleanup area .
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2022 at 11:20am
How much information is in poured concrete after cure ?
Class toured both a batch plant and then a testing lab for concrete .
At test lab there was a concrete block about 1 ft in length and 2 ft wide and 2 ft depth
Rough surface outside - 2 holes in block (kind or round shape)
 Lag tech gave info on it - was from Las Vegas area desert , holes were where legs of individual were encased after burial in desert , concrete block was cutoff of full grave site slab .
  Lab work determined the brand of cement mix , batch date , wholesale supplier , then checking for supplier records of large sale of bagged mixes during certain dates , traced to purchaser . Murder Solved - person arrested , convicted , and lab kept a sample of the evidence .
  Seems someone killed someone , then buried them in desert but encased in concrete so as to not be dug up by some animals . Forensic information of cured concrete let to the purchaser and the date of sale from local hardware store based on volume and material content of components ...
  That concrete trophy setting in that lab, where the holes use to hold a set of legs --creepy at least .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2022 at 5:37pm
Originally posted by AllisFreak MN AllisFreak MN wrote:
I gotta admit, he was entertaining. Did he pizz off the Mod?
Don't have a clue as to what happened.  Don't care much.  Maybe it was burnout, maybe something else. Too bad, he used to rail at all the guys with over 20K posts, yet never made it much past 4.5 K!  A bit of irony, to chuckle at...Wink
This page was generated in 0.127 seconds.
