Coil to mag type ignition
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Topic: Coil to mag type ignition
    Posted: 07 Jul 2019 at 7:48pm
Magnum 18 refit into a Brand X garden tractor. The old VT-17 was coil ignition. The new, magneto. The wiring is a salad. I want to wire a new stand alone start/run/charge circuit. Any suggestions or schematics.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2019 at 10:54pm
make sure that you change the key switch so that ground is off and no power can go to the ground or the magic smoke will come out of the magneto
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2019 at 11:00pm
wiring is very simple we are doing an older jd116 that the wiring had been butchered very bad so we are going to re wire it this week with a pto saftey switch this will have completely new wire i will draw a diagram when we do it
This page was generated in 0.320 seconds.
