Coil Hook-up
gary(nmo) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gary(nmo) Quote  Post ReplyReply Direct Link To This Post Topic: Coil Hook-up
    Posted: 06 May 2011 at 11:39am
With a 6 volt positive ground does the plus or minus side of coil go the distribitor? Also with a 12 volt neg, ground  does the plus or minus side of coil go the distribitor? Thanks Gary
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 11:44am
Both 6 & 12 volt coils need to be connected to the distributor using the same grounding system as the battery. The coil in a Pos grd battery needs to have its pos terminal connected to the distributor, the coil in a Neg grd battery needs to have is neg terminal connected to the distributor.
