Print Page | Close Window
Coil Hook-up
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=30336
Printed Date: 13 Aug 2025 at 7:53pm
Topic: Coil Hook-up
Posted By: gary(nmo)
Subject: Coil Hook-up
Date Posted: 06 May 2011 at 11:39am
With a 6 volt positive ground does the plus or minus side of coil go the distribitor? Also with a 12 volt neg, ground  does the plus or minus side of coil go the distribitor? Thanks Gary
Posted By: GregLawlerMinn
Date Posted: 06 May 2011 at 11:44am
Both 6 & 12 volt coils need to be connected to the distributor using the same grounding system as the battery. The coil in a Pos grd battery needs to have its pos terminal connected to the distributor, the coil in a Neg grd battery needs to have is neg terminal connected to the distributor.
