clutch adjustment Model U
Roger Nolin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Nolin Quote  Post ReplyReply Direct Link To This Post Topic: clutch adjustment Model U
    Posted: 11 Jun 2010 at 5:38pm
got the new clutch disc in. adj bolts screwed all the way in. finger out toward throwout bearing. 1/4 in between finger and bearing. start it up push clutch all the way down. cannot get in gear due to continuous grinding. HELP   thanks< id="gwProxy" ="">< ="jsCall;" id="jsProxy" ="">
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2010 at 6:55pm
Ajust the length of the rod( with yolk) from the pedal to the cross shaft, your throwout bearing can be much closer than 1/4 inch, just as long as it's not touching.
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Nolin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2010 at 7:18pm
Leon, there is no rod on my 35. pedal mounts directly on shaft with key way. i/4 is recommended clearance according to the manual. only adjustment is the fingers. thanks< id="gwProxy" ="">< ="jsCall;" id="jsProxy" ="">
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2010 at 7:39pm
Call me 717-451-6590 8 am to 9 pm eastern  time
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Nolin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2010 at 11:43pm
will call in the morning Fred thanks< id="gwProxy" ="">< ="jsCall;" id="jsProxy" ="">
