Clunk and Ticking in Left Rear of '39 B.
sjparadiso View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sjparadiso Quote  Post ReplyReply Direct Link To This Post Topic: Clunk and Ticking in Left Rear of '39 B.
    Posted: 29 May 2010 at 8:17pm
Well, my 1939 B sat all winter in the garage and started up today without a hitch.  As I rolled it out for the first ride of the year, I noticed a clunk and a ticking sound in the left rear.  It doesn't happen on each revolution, but does happen with a rhythm and changes with speed.
Being a city boy with a tractor (less than a year), I've not a clue as to what it could be.  Any ideas would be appreciated.  THANKS!
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 8:26pm
The B has splines and a tightening nut on each rear wheel hub.  I would suggest that you tighten the left rear nut.  Hopefully that will do the job.
Take good care of my favorate.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 8:32pm
put a floor jack under the drawbar on that side and raise the rear wheel 2 inches. rock and roll back and forth and look as Bill said. wheel clamps or center nut is a good bet.. brakes still work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote sjparadiso Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 7:23am
Thanks Bill and Steve - will do as suggested and get back to you.   And yes, brakes on both sides work just fine.
StewartMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 8:51pm
We had a clunking noise coming from the right rear of our wd.  It ended up that one of the wheel weights came loose.  Not sure if your B has rear wheel weights but it's atleast a thought.  Good luck.
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
Post Options Post Options   Thanks (0) Thanks(0)   Quote sjparadiso Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 8:21am
Thanks StewartMD - I do have wheel weights so I'll indeed check that out.  Appreciate the idea.
This page was generated in 0.067 seconds.
