clipping dry beans
thumb farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thumb farmer Quote  Post ReplyReply Direct Link To This Post Topic: clipping dry beans
    Posted: 31 Aug 2010 at 7:04am
 has anyone used an F , G,M,orL for clipping dry beans. If so did you use a spike or rasp cylinder. if spike why? or if you used a rasp why? I have both but was told that the spike has a tendency to throw bean and resadue forward and re chew . what are your experiences? thanks and good luck to all in the fall.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2010 at 4:54pm
I've never used a conventional combine for dry beans but, have two C II's and one for years was used only for dry (white)beans by the previous owner. It has a spike cylinder and he loved the way it worked. My dry bean experience is with large beans such as dark red kidneys, crans, Otebos, etc. We started with Lilliston bean combines and ended with a BOB's 666. the Bob had two spike cylinders and the least seed coat damage. Ivan Summerix and his Dad were also kidney bean sead growers and could likely give you some good advice.
MI8050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI8050 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2010 at 8:19pm
Always thought the spike cyl machines found their home in MI dry bean country.  Not sure why??  My friend runs them near Breckinridge with a 9400 and has to switch some things each year for dry beans, its a few hour conversion what ever he does to it.
MLGoodwin82 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MLGoodwin82 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 11:35pm
thumb farmer, where exactly are you at?  I'm in Sandusky.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 7:26am
I have used both my R52 and a L2 and M2 for white beans.  I have never had a spike cylinder, always used the standard cylinder in the machines.  I have not used the R52 since we converted the cylinder over to Hyper Harvest arrangement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote thumb farmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 8:38pm
I'M north west of Ruth. IF you yere at the pull in Sandusky , the D21& XT were ours
