chaning corn head spacing
clint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Topic: chaning corn head spacing
    Posted: 22 Feb 2010 at 9:19am
lm 438
on 38 to 36
just need the 2 spocket things right? then move everything over?
how long would that take?
if i do that i might go to 34- but then i wouls have to do 2 heads and 2 planters
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2010 at 2:10am
that is one helava job!!
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2010 at 2:47am
is it a black or orange corn head? the black uses the same parts just a shorter or longer main beam everythings adjustable on a black head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2010 at 6:08am
With my Wood Brothers I just drive a little closer to the row I'm pickin'. LOL I couldn't resist.
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2010 at 11:22am
black head
how long of a job is this?
skipwetle NWIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwetle NWIA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2010 at 2:02pm
Ive done a few row spacing changes on the black heads,  its an all day long affair as all the bolts comes out of the tin work, all the row units have slide, the worst was the torx bolts holding the wear plate at the end of the snaping rollers, it might break off or strip out.  Now these heads were new, everything wasnt rusted, the first one took a couple of days the second a little longer that a day.
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2010 at 4:05pm
You will need to get different coupler shafts for between each row unit.  They are specific for each row spacing.
The innovators offer what others will imitate.
This page was generated in 0.075 seconds.
