changing bush-hog blades best way I know how
marion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marion Quote  Post ReplyReply Direct Link To This Post Topic: changing bush-hog blades best way I know how
    Posted: 02 Apr 2018 at 6:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote marion Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 6:56am
mothers day is coming up, smaller white lift would make her a nice present
any serious people that need a good lift can p.m. me. diesel motor
central ar.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 7:07am
Marion, where are you located?  I'm guessing NC as a first choice, GA second....
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 7:57am
We change them at the farm by lifting the mower from the front and standing it up,with the payloader.  since its a Woods 21' we use the loader to lift the blade assemblies on and off the spindles. it goes pretty fast but you need a 1" impact to get the bolts out. once the blade assembly is on the bench swapping the cutting edges is real easy. my little L306 I stand up with the tractor loader set it on the front edge that way I can stand up pulling the blades and cleaning the bottom. I do it every fall before hanging it on the wall for winter.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 8:21am
I always either raise the mower with the tractor and block the arms up, or just lean the mower sideways up against a tree/large post, and secure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 8:25am
Then there was the time mine had sat for a few years and the PTO shaft was seized to where it wouldn't telescope.  After many sensible strategies to free it failed, things got crazier as I got madder.  At one point, I had lifted the entire thing off the ground by the front yoke of the PTO and was jerking the loader up and down.....still wouldn't budge.  Guess I could have changed the blades then!  Who would think rust was that dang strong!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 8:26am
gee, I'm impressed you made a 'pass though' garage !!
and really you're 'supposed' to change blades ??hehehe
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 9:36am
I picked mine up with a chain fall while hooked to tractor .Seemed pretty safe.Guy  got killed by one falling on him  not far from wherei i live.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 10:59am
It's always a PITA.  I use jack stands to hold the lift arms up and proceed to start cussing as the bolt is one of those that is tight the whole 20 turns to get the nut off using a 6 foot cheater pipe.  A good workout for sure.Thumbs Down
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 11:38am
Tractor lift then drop it on precut to length tree stump here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 5:09pm
I agree, pick it up on one end so it's staring you in the face.  Those barrels are STILL too low for me to crawl under...My back hurts enough.  Stand it up straight so you can work on it standing up straight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 6:27pm
Uster do it from underneath, on the AC 160, just back up to a bank, lay on the ground, and TCB.  then I gots the kuboter, and a cheap howse 4' BH. first did it from underneath, and hadda drop that 80 lb stumpjumper and the blades, drag the SJ assembly out from under, and then take the blades off.  Then I got out the hole saw, and drilled a hole in the deck, on that SOB!  Now it takes about 15-20 mins.Wink
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 6:41pm
Used to put mine on jack stands and crawl around underneath and hope it don't fall over on me.
Now I just stand it up and battle is on only easier.
This page was generated in 0.089 seconds.
