Chainsaw opinions |
Page 123> |
| Author | ||
DougG
Topic: Chainsaw opinionsPosted: 06 Oct 2019 at 8:42am |
Looking to up grade chainsaws , have a 038 Stihl Farmboss that I've had for 30 years, it works good but someone said an 029 super will out cut it big time and a lot lighter too,, any experience with them? What's everyone using?
| Sponsored Links | ||
nella(Pa)
Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3145 |
Posted: 06 Oct 2019 at 9:12am |
Echo EV650, for 35 yrs. and still works good. It sawed a lot of wood and was backer over by my D17(dumb tractor), took 1 part for handle mount to repair.
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 06 Oct 2019 at 9:16am |
I use Homelite SXL's have for years. ---The best brush saw is an Echo cs310 . I use an Echo cs 8000 on a sawmill attachment. Have several other oddballs tossed in, but they get the job done. ---General med. cutting I grab a Blue-Max. ---not a bad saw for the money. The sthil ms250 is on the de-barker. I had major starting problems with it and for a couple of years it sat in the junkpile.--drug it out and put a new chimina carb on it and now it starts/runs. former owner bought it new and never could get it started so he gave it to me.--I barely could start it so tossed it in the junk.
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4939 |
Posted: 06 Oct 2019 at 10:17am |
I have an 029 and a 440 Magnum, love them, had the 29 for maybe 15-16 years, never had an issue
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
DougG
Posted: 06 Oct 2019 at 1:14pm |
Curious how much the 029 weighs,, spec on my 38 FB says 14 lbs and I believe it ! 20 years ago was no problem ,, pushing 50 now and Arthur Arthritus says differ !
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35655 |
Posted: 06 Oct 2019 at 1:31pm |
I own a MS250, good saw for the money, mine (Knocking on wood) has never failed to start and run, also invested in a MS192, great little pruning saw. Have an OLD Poulan Countervibe 3400, has been THE best saw I ever owned, still starts and runs, smokes a lot these days as has HUNDREDS of hours on it, bought that one just at 35 years ago. Was when Hill Behan Lumber was in full business, they had it as a demo, would not run so I got it for $110 and tax, got it home had the chain guides in swapped where had chain pinched, swapped those was GREAT, two bars, who knows how many chains been on it, JUGS of chain lube.
Dakota Dave
Posted: 06 Oct 2019 at 7:32pm |
Still using and old Poulan 2300 CVA. I've had it since 1986 been throug a couple bars and many chains. Mostly I do trimming and take an ocasional tree down. It's a very light saw and suits my needs. If I needed a heavier saw I'd buy something else. I do have a husavarna but it's too heavy to be doing trimming above my head. My wife bought me a Remington weed wacker pole saw this year it's been great for cleaning up fence lines. Only has a 6" blade but you don't need much to keep the Russian olive branches trimmed back. And the long reach means I don't need to get into those thorny trees to trim.
Joined: 11 Sep 2009 Location: illinois Points: 90793 |
Posted: 06 Oct 2019 at 7:36pm |
MS250 here............ great saw.
Dakota Dave
Posted: 06 Oct 2019 at 7:48pm |
We've 2 MS 250's at the farm the old one works great the new saw not so much. It burns up chains it's been back to the dealer twice. For some reason it doesn't oil like it should. If I could find out who borrowed them I'll dissasembled and check the oiler.
200Tom1
Posted: 06 Oct 2019 at 7:56pm |
I have a mid sized Echo. It has worn out several bars, numerous chains but it just keeps on running. I couldn't begin to count the truckloads of wood it has cut. After 20 + years of use I had to put a clutch in it. We were cutting hard wood that has been laying off the ground for years. The Echo dealer said it was totally unusual to replace a clutch on one.
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10933 |
Posted: 06 Oct 2019 at 8:12pm |
I like my Husqvarnas. Have a Homelite tophandle too. Great saws!
klinemar
Joined: 14 Sep 2009 Location: Michigan Points: 8074 |
Posted: 06 Oct 2019 at 8:50pm |
Stihl O26 and 461 plus a Husqvarna 240 for triming. The O26 I bought new 28 years ago. Still runs and cuts but beginning to show it's age!
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 06 Oct 2019 at 11:38pm |
I've got a Husqvarna 141e that I've had for about 30 years or more. It has never not started. If it doesn't start on the second pull, then there is something wrong. (Now that I've said that, it'll be a bear when I go to use it on Thursday.)
I just bought a Husqvarna 440e cause I got such a deal on it, I couldn't turn it down. The Husqvarna is preferred by professionals and the Stihl is preferred by home owners. That is a fact I found on the net when I was checking on my new saw. All depends on what you are going to do with it. Cut down BIG trees? Little trees and limbing? The Husqvarna cuts faster, but the Stihl has more starting torque so it doesn't get stuck as easy. |
klinemar
Posted: 07 Oct 2019 at 7:50am |
Ted, where did you find the fact that Husqvarna was preferred by Professionals over Stihl? My experience in talking with Loggers in this area is price and Dealer parts availability. When I took a trip last year visit my daughter in Alaska I attended a Fair in Haines Alaska and they had a Logging Competition. I couldn't see a Husqvarna Saw there! All Stihl. Both Stihl and Husky make Pro Saws and Homeowners Saws. Now with. John Deere selling Stihl a lot of the small dealers are upset. Same with Husky with TSC and Big Box marts selling Husky. Buyer beware in the Big Box marts as you don't find pro saws or anyone that knows anything about them. I have had Homelite, McCullough still have the Stihl and now Husky. The Husky I bought at TSC because it was cheap. It is not a Pro saw and I have to adjust the carburetor a lot. I don't see this saw lasting as long as a Pro saw in either Stihl or Husqvarna. Goes back to the old saying you get what you pay for!
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 07 Oct 2019 at 8:04am |
I got a McCulloch Eager Beaver 3.7" 610 16" Chainsaw, back in 93 and has had no problems ever starting or cutting. But like our old Allis's, parts aren't falling out of the trees. Edited by chaskaduo - 07 Oct 2019 at 8:07am |
nella(Pa)
Posted: 07 Oct 2019 at 8:55am |
The logger that timbered off my woods used Stihl saws with a skip tooth chain on them.
ac fleet
Posted: 07 Oct 2019 at 9:04am |
Chas!!--I forgot the Eager Beaver 3.7.s, --I have a couple of them, still use them for some of the bigger stuff. --- We did firewood for 18 years and at that time used a new Homelite 8800 with a 36" bar to do the big stuff then the 3.7 for med and a baby beaver 2.0 for limbs. ---- later started getting unwanted saws and fixing them to run 235 Husky is a nice little saw, a bit heavier than the Echo 310. Blue Max is about the 235 weight, seams to cut faster as the chain speed is faster, which I don't care for. ---slower chain = more grunt, longer chain life, less heat build-up,etc. Poulans are ok too, I have several of them and use them too. ---I never was brand loyal to anything! --- all brands have duds as well as great units. I seam to have the gotten only junk sthil ms 250! -- When I finally got to the problem and fixed that, now it starts pretty good, NOT as good as the Echos or homelites, or Husky, but now I can use it.
200 10and20
Joined: 20 Jun 2019 Location: Tim Buk Tu Points: 217 |
Posted: 07 Oct 2019 at 9:16am |
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6610 |
Posted: 07 Oct 2019 at 9:37am |
Dealer service is the driving factor for me. I have two Stihl 028 Wood Boss models and love them, one survived a dive into 12 feet of water with not problems "stihl" going strong. And I was crazy enough back then to dive down into a tree top to find it.
Thinking of getting a 170 or 180 for limbing and light cutting. I need to try out the Jonsered 625 I traded a toy Poulan for but it has been way too hot here.
Ted J
Posted: 07 Oct 2019 at 10:03am |
I've used HUNDREDS of saws. Yes, that is right HUNDREDS!! On our little city of over 50,000, the fire department of which I was a member for over 30 years, used both for a while, but just about everyone would rather use the Husqvarna. That is all we had on the rigs for the last 15 years or so. How many fire department axes have you ever used Joe? So, you opinion is welcome, but when you start spouting something that isn't true, you had better be prepared to back up anything you've stated. Sorry to the rest of you guys, but up until now, everyone has stated which saw they like and the reasons for doing so. No one, up until now, has said anything degrading about another manufacturer. Give an educated opinion if you want. Two years is not long enough to form an opinion. I'm 70 and I've had mine for OVER 30 years. Now THAT'S an educated opinion. If you like your saw, say so. If you don't like another that you have no experience with, don't say anything. |
Ted J
Posted: 07 Oct 2019 at 10:19am |
https://www.thebalancesmb.com/stihl-vs-husqvarna-chainsaws-2218119 |
200 10and20
Posted: 07 Oct 2019 at 10:28am |
Edited by 200 10and20 - 07 Oct 2019 at 10:54am |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12418 |
Posted: 07 Oct 2019 at 11:08am |
Usually don't see this kind of ornery until February or so.
200 10and20
Posted: 07 Oct 2019 at 11:12am |
Hey Tbone, I just gave my opinion like everyone else and apparently struck a nerve with Paul Bunyan.
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4873 |
Posted: 07 Oct 2019 at 11:21am |
I have used 6 saws in 50 years of cutting. Use to be Homelite but they have been thrown under the bus till there name was no worth saving. Echo saws have served me well but are not the most powerfull for size. But I don't hurry much anymore, and like how Echo starts compared to others.
Now for Ted's beloved Huskis brother in law bought a small trimming saw. From a full time saw and small engine shop. They said it was the best,could of been if it would of started good. They fussed with a number of times,never got better. The other Husky was a big one with 40+ inches of bar. Was only 3 or 4 months old and the first time I used it the dang think seized up.It had cut the big stuff in 2 other big oaks. Same gas in 2 or 3 other saws,I did not mix it or fill it just holding it in the big stuff. They did rebuild it on warrenty and since the BIL is gone it is here,and we use it time to time. But always the back of my mind will this thing blow up again.
Tbone95
Posted: 07 Oct 2019 at 11:38am |
Well alrighty then. |
shameless dude
Posted: 07 Oct 2019 at 11:39am |
started with Homelights (dad's), and thru the years had a few more, they were mostly always hard to start (lots of pulls). bought a new Echo and have had them about ever since. bought a new Poulan and ran it for a day, traded it off the next day for another new Echo. can't count how many semi loads of firewood or trimming I've done with the Echos. I've run Stihl's, they seem to run a lot higher RPM's than the Echos, oh and I did try a Huqusvarna in this bunch, still have it, but the carb needs work to stay running.
Tbone95
Posted: 07 Oct 2019 at 2:45pm |
Very very sad my image didn't show up.
![]() Anyway, in the waaaaayy back machine, dad had an old Poulan, the ones that were the color of a filing cabinet, weighed 100 pounds, ran about 10 RPM.... Then a buddy of his had a sharpening and saw work shop, set him up with a couple of McCullough saws. Seemed.....average. Then we got a Deere, 80 EV, which was made by Echo. Beast of a saw. Would still be using it today, but the muffler is burned out and obsolete. So it discharges right onto your hand and gets pretty warm in short order. I have 2 MS 290's. One is 10 years old, the other is 3 years old. The older one has always been a cold blooded SOB, at least 10 pulls when it's been sitting. Dealer swears there's nothing wrong with it. Newer one starts on fewer pulls, but pulls harder. It's got ever so slightly a bit more power than the older one, and I'm guessing by the feel it's in the compression (new vs. new that is). Both great saws that I use a LOT. 18" bar on the new one, 16" on the older one. Like to have something just a bit more powerful and maybe a 20 inch bar. Me likes power.
exSW
Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Posted: 07 Oct 2019 at 3:04pm |
IF you have a good dealer get a Dolmar. Now known as Makita in the US. Built like a Stihl run like a Husky.
Goose
Joined: 07 Oct 2009 Location: Melrose, Wis Points: 2471 |
Posted: 07 Oct 2019 at 3:06pm |
I like my Husqvarnas. I have seven of them, ranging from 38 cc to 65 cc. They're easy to work on, light and well balanced. They've had many hours of use and still running strong.
"People are human beings, produced by the society in which they live. You encourage people by seeing the good in them." ~ Nelson Mandela
Page 123> |
