Casting Numbers
boilerrepairman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boilerrepairman Quote  Post ReplyReply Direct Link To This Post Topic: Casting Numbers
    Posted: 31 May 2011 at 4:44pm
I'm a bit confused. My B is a 1938 by serial number B 3271. The casting numbers on this unit all end in -8 even the engine. From the info that i've seen on casting numbers 1938 castings ended with -10 so if my math is right and Allis followed with there numbering my casting where done in 1936? Am i wrong or miss lead?
1938 Model B 3271
Former owner of 1939 WC
Proud Veteran US Navy 1985-1994 GSM1/E-6
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 7:54pm
I think as Glen would tell you there were none earlier than 1937 which had a suffix of -9. Are you looking at the casting # on the right side behind the governer rod?
This page was generated in 0.204 seconds.
