Carco Winch for 65 HD-6
kblackav8or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kblackav8or Quote  Post ReplyReply Direct Link To This Post Topic: Carco Winch for 65 HD-6
    Posted: 05 Nov 2018 at 9:31pm
Which Carco winch fits on a mid 60s AC HD-6?  Will be looking for one in the Pacific Northwest in the next year or so.
donoman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 6:55am
Carco E30 S-G or E24 the older EA Carco will also work but the E30 is the best of the 3
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2018 at 6:28pm
Have a HD6G with a Carco on it. I'm too far I'm sure (Ontario Canada) but it is available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kblackav8or Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2018 at 7:49pm
Right now it would be nice to find one next summer.. maybe.  It is a definite thing I want to put on the one I am buying once I have it and deal with some other projects.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kblackav8or Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 2:43am
I found an E24 locally.  They want $900 for it off a IH TD-9.  No cable but it has all the control levers etc.  Can anyone tell me about the E24?  It looks a bit rough.  I was thinking of offering less for it.  I don't likely have a lot of big winching to do, some decent sized alder and maybe the occasional bigger fir.  I haven't bought it yet.  Want to know it is will work for what I need.
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 3:38pm
E24 is ok; BUT drive shafts are different HD6 to TD9; so do some carefull checking of pto splines and driveshaft lengths.
Am 'told' driveshaft will fit but winch needs spacing back, or shaft needs modifying.
Stud patterns are same for TD9 and HD6.
The drum disconnect on a E24 can be weak; make sure they are fully engagaged if you have used the freespool. Other than that they are a good winch.
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote kblackav8or Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 7:25pm
Looks like I will keep shopping.  It dropped off Craigslist already.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kblackav8or Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2022 at 11:16pm
Will a Carco E work of a TD-9.  I know that is an old one.
