carb kit for a gas 2200 on an h 4 allsis crawler |
| Author | ||||
pinball
Joined: 28 May 2014 Location: missouriu Points: 6458 |
Topic: carb kit for a gas 2200 on an h 4 allsis crawlerPosted: 06 Oct 2021 at 11:59am |
so my Allis H- 4 started running bad. it has the 2200 gas motor. I pulled the carb off and took it all apart to clean. it says zenith on the carb and I haven't found any numbers. so I need a kit for it. I've found some om eBay with what looks to be the right bowl gasket but none say for an Allis h4. anyone know the right number i need to look for or where you might have bought one before. any info is appreciated. thanks for reading.
| Sponsored Links | ||||
orangeman
Posted: 07 Oct 2021 at 9:01am |
Pinball: have you tried reaching out to The Carburetor Shop LLC in Missouri?
Joined: 11 Sep 2009 Location: illinois Points: 90733 |
Thanks(1)
Posted: 07 Oct 2021 at 9:35am |
motor.................... carb........... carb # ......................... kit
orangeman
Posted: 07 Oct 2021 at 9:41am |
Adding to Steve(Ill) information - AC H-4 parts book shows Gasoline Carburetor Repair kit for H-4 Gas Crawler as Part Number 4056411. Excerpted from page 193 Form 1012402 Reprinted 11-1975 replaces form TP-104.
Also - see Zenith information here: http://www.zenithfuelsystems.com/downdraft_228.htm Might work if no kit available. HTH's - Orangeman
Edited by orangeman - 07 Oct 2021 at 10:00am |
pinball
Posted: 07 Oct 2021 at 4:08pm |
Thanks for the info.
