CARB FIXED - First start of Allis C
easygoin4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote easygoin4 Quote  Post ReplyReply Direct Link To This Post Topic: CARB FIXED - First start of Allis C
    Posted: 22 Nov 2015 at 3:25pm
Couple questions: (FYI- I have never had this thing running, bought in pieces, she is back together, looks great, going to fire it up soon)
Can I hand crank the engine w/o plugs, with oil in it and prime it- wait for oil to come our little oil line to Mag.  The engine was put back together with assembly lube and alot of oil, now pan is full and new filter is on.
Next Question- I rewired completely, it was a hand crank, and now will be both 6 Volts.
All went together great and I have manual.
I purchased used box with 3 position light switch, new Amp meter and Mag shut off.
If I pull the light switch all the way out should the lights come on NOT RUNNING.
I tried pushing the starter button too and nothing.  Brand new battery but will check voltage.
Any advice would be great.. Keeping my fingers crossed...
thanks
Edited by easygoin4 - 03 Dec 2015 at 5:00am
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 5:11pm
I don't think hand cranking is going to move much oil around.  I would just fire her up.  You could use the starter the move some oil if you wanted.  Just disconnect the coil wire.  Although, this could cause problems also.  As far as nothing happening with the new battery, make certain you have a tight, metal to metal connection to the leads.  The amperage is very high in a 6 volt system and it won't work without very good connections.  Been there, done that.  Good luck and let's see some photos!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 5:18pm
With everything being apart and you not having started it this is always a interesting point. First suggestion is go slow and don't question everything. Dont start taking things apart.I know I have been here before too.
You have built and assembled it to a condition that is probably better than when it was new. You may have one little thing, like no ground that is causing your starting issue. Go over the electrical with a continuity tester and or multi-meter to make sure you have power.
I don't have one of those pull switches, so cant answer if the light should come on?
And I always have electrical issue, Just me and my lack of knowledge.
I am sure you can hand crank the engine but not sure it will prime the oil pump? Someone like Dick L will be along to answer that. If you have plenty of lube as assembled then I would just start it up and check oil pressure gauge.
I think once you find the issue it will be pretty simple.
We could use a couple pictures too:)!
GaryL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GaryL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 5:27pm
Some guy coined a phrase on the VW forum years back: "Hit it with an axe!"
It might help
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 7:04pm
The light switch is normally a three position switch. In should be low charge, mid position is for lights and all the way out for high charge. Best I remember the lights could be turned on without tractor running. Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote easygoin4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 7:39pm
i agree that was my thought to start from beginning and check wiring with meter. I have added a few pics- first one is when I got it in the summer.  Its not a show condition restore but good enough for this city guy who likes these old toys.
Thanks will keep you posted as to what I find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 7:54pm
I beg to differ.  That is a beautiful tractor!  Very nice attention to detail.  Nice work!
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 8:19pm
Looking good, like the seat and fenders.
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 8:34pm
nice!
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 8:43pm
Looks real good.
To prime the oil pump and get oil thru the system I like to put a hose on the filter stand pipe with it long enough to hold over the rocker arms. I fill the hose with motor oil and let it seep down once or twice. With the hose full and without spark plugs I run the starter until oil is running out of the hose over the rocker arms. I then replace the filter, the spark plugs and start the engine.
I check for spark at TDC by hand cranking before priming the oil pump. I do this by making sure the CENTER or TDC line is in the inspection hole the instant I get spark on number one plug wire on the compression stroke. That is when both rocker arms are up on number one cylinder. As you might guess from the above I do not put the valve cover on until I have it started. I then only set it on until it has warmed up and I have retorqued the head bolts as well as reset the rocker clearance.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 8:53pm
Originally posted by easygoin4 easygoin4 wrote:
I purchased used box with 3 position light switch, new Amp meter and Mag shut off. If I pull the light switch all the way out should the lights come on NOT RUNNING. I tried pushing the starter button too and nothing.  Brand new battery but will check voltage.
Hmmm... IIRC the lights should be connected so they operate in an off(in) on (first position) and off (second position). Sounds like wire swapped.
Pushing starter button and nothing... well, that's the simplest circuit on the planet... you've got one side of the battery grounded, the other side to starter switch. When switch closes, you have a current path going from battery, to starter switch, through starter switch, through starter windings, to ground, and back to battery.
Something on that path is incomplete.
I would look at all your connections, particularly the ground wire connection to the tractor, and the nose of the starter, as these are very necessary contact surfaces... if there's paint on them, you won't be carrying current on the ground side of the circuit.
Since this is a C, I would also check the starter switch contacts. very frequently, the starter switch contacts on Bs and Cs, become intermittant or fail, yielding a no-response-to-starter-switch condition. one can eliminate this as a problem by disconnecting the battery, removing the starter switch, and applying a jumper cable to the battery post, and the other end to the contact surface on the starter. MAKE SURE that the tractor is chocked and out-of-gear, so that if the starter turns the engine over, the tractor doesn't drive over you..
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 8:58pm
Sugarmaker,  That is one BEAUTIFUL JOB!!  I can assure you they never looked that good new.
Listen closely to what is said above.  You are getting advice from some GREAT mechanics.
You will find the suggestions and advice to be very correct and exceptional.
The C has the B-C-CA engine which is about a simple as you can get.  In fact, I even worked on them and had success.
Thanks for bringing the C back.  To me it is one of the nicest looking A-C tractors.
Happy Thanksgiving!
Good Luck!
Bill Long
MrHDC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrHDC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 9:03pm
"It's not a show tractor"
What a crock!! LOL! Looks like a show tractor to me. Good job.
Hervey
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 9:06pm
You are doing a great job on the tractor. Looks good!!
On your 3 way switch. Knob in, charge 3 amps, knob in first position, lights on high charge, all the way out, just high charge.
Check for voltage at the starter switch on the starter to chassis gound. If present then remove the switch and clean the contacts. They can get corroded from sitting as can the points in the mag.
The C is a great little tractor and fun to drive. I love mine.LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 1:22am
I agree...that is a sweet little tractor again! nice job!
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 6:33am
As nice a job you done on that C I'm very confident you will soon have it running !!   When it comes to life you will have a ear to ear smile as we all do at that point. You have a very nice tractor.      Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 7:06am
On the light switch, the guys pointed out the correct information on how it works. Also, I would like to add, that make sure where the switch is bolted inside the instrument box that it is clean and free of paint under that switch. This switch is a multi-function self grounding switch, and it needs to have a good ground in order to work correctly for the charging side of the system. New paint makes a great insulator.
As for priming it with the hand crank, I doubt very much if that will work unless you have an arm like Superman. I always pour oil down the oil pump pipe and fire it up. Your no start condition sounds like a connection that isn't clean or is insulated from the new paint job. Its probably something simple. You'll find the problem...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote GaryL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 7:26am
I had no idea the Model C was so small.  Bloody hell, I might as well add another to the list.
Post Options Post Options   Thanks (0) Thanks(0)   Quote easygoin4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 2:18pm
Thanks for all the advice and compliments...
I had similar problem with lights on the Massey I recently did, too much paint.LOL
So this time I took a wire directly to the ground bolt (which may still need paint removed) and wired the light switch, front and rear lights dierectly to this to be sure I had a good ground.
Yes ran 2 wires to each fixture...
I am sure its a contact thing for starter, but will open box back up and test every circuit- Love a challenge..
Thanks agian to all of you..
Will let you know what I find..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 3:43pm
you know where the starter sticks into the bell housing, the wall must be clean and no paint........ the 5/8 inch set screw pinches things together to get a good ground for the starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 5:40pm
Check the fuse in the box.
1C 1 WD45 1 AC180
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 7:18pm
Happy Thanksgiving!
Good Luck!
Bill Long
Bill,
Its not mine, but this is a very nice tractor!!!!! Looks like it belongs to "easygoin4"
I think it would rank right up there with a high quality restoration!
Edited by Sugarmaker - 23 Nov 2015 at 7:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 7:25pm
Gary,
You do need one of each!:)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 7:30pm
Easygoin4,
 Don't pull one like I did. Was painting the starter switch contact assembly. Well I placed a piece on masking tape on the inside so as not to get paint on the contacts. Yep you guessed it. I forgot to take the tape out when I put it back on the starter! Masking tape makes a great insulator! Pulled the contact switch back off, took the tape out and the tractor fired right up!Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 9:38pm
When I install a 3 position switch I run a wire from the 10-24 stove bolt to the battery ground bolt on the post. That way I'm sure to have the switch grounded.
Yes, be sure to clean the rust and paint from all ground connections. Paint and rust are great insulators. LOL Bob
Rog(NCWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog(NCWI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 9:42pm
On my Model B, if I pull the light switch all the out the lights stay on just as they do on the first notch. Is this right? The amp gage shows about 3 amps when all the way in and about 12 amps all the way out. Not sure on the middle setting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2015 at 7:35am
The Headlight/Tailight circuits get connected to the "S" terminal on the 3 pos. switch. Headlights will come on in middle position. Third position, lights out, high charge only. Your charging rate is fine...
Post Options Post Options   Thanks (0) Thanks(0)   Quote easygoin4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2015 at 4:47pm
Update. Fuse blown, lites work fine, however the mag. Switch is not right grounds out whether in or out. So disconnected it at mag for now and has spark. I put plugs in and she fires up or only few seconds. I feel is is a gas issue, but fuel dripping out tiny plug in bottom of zenith carb.
Also the throttle rod at carb does not seem right, the stop set screw is not in closed position its like it stays open quite a bit. I do have the correct spring on rod to manifold bolt.
Next question..do all 6 volt systems crank slow. I have brand new battery and starter just cranks slow. I have hand cranked till arm sore it will fire but dies right away. I do have good ground now. Thinking about throwing 12 volt charger to starter to get it going.
Any thoughts... thanks
It was nice to hear run and sounded great, no smoke either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2015 at 5:16pm
The 6 volt systems worked for years fine ( with regular maint.) till people started replacing cables with "off the shelf" stuff NOT made for 6 volts. Cables NEED to be BIG, connections CLEAN , that means NO paint between starter and block and no paint between ground connection and block.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2015 at 9:17pm
I think you have a few minor problems.  The carb must have one of the internal passageways plugged or the float is messed up OR the gasket between the carb and manifold is leaking air.
For the electric side, there has got to be a bad ground or bad positive side connection.  You are very close, it will run soon, believe me!
Allis Express participant
This page was generated in 0.191 seconds.
