Can you machine a Allis 160 flywheel |
CleaningGuy
Joined: 11 Oct 2024 Location: Green Bay WI Points: 5 |
Topic: Can you machine a Allis 160 flywheelPosted: 11 Oct 2024 at 10:51am |
Hi all,
I'm working on an Allis Chalmers 160 flywheel (see picture attached) and had a couple of questions about machining it. Specifically: 1. Can the flywheel be resurfaced using a normal stone wheel, or does the pressure plate mounting surface need to be milled separately to maintain proper alignment? 2. If I were to remove about 0.010" or 0.020" from the clutch face, how can I ensure that I maintain the correct clutch clamp force? Are there any adjustments needed to account for the material removed? Any insights or tips from someone with experience on this model would be greatly appreciated.
Alvin M
Posted: 11 Oct 2024 at 2:44pm |
Flywheel step must be .175
CleaningGuy
Posted: 13 Oct 2024 at 12:41pm |
Yeah, I understand it can be machined to a .145" step, but how do you machine the middle portion where the clutch assembly mounting bolts? Most machine shops around here only have two types of grinding wheels, and I'm not sure if they have the right equipment for this part of the job. Do you know if there's a special tool or process required for that middle section? Or would milling be the better option?
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8684 |
Posted: 13 Oct 2024 at 10:58pm |
Take it to the machine shop and let them determine if they can do it. When they did my Cat flywheel they cut the disc surface then raised up and cut the mount surface to establish the step.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4145 |
Posted: 14 Oct 2024 at 5:33am |
Any competent machine shop will have a grinder that will handle that. Tractor flywheels all seem to have a step.
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 14 Oct 2024 at 7:07am |
The problem most common machine shops have doing these is because the pressure plate step is below the disc surface .I have a machine shop that can do these . Been doing these a long time . Maybe post another picture showing this step a little better.
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
CleaningGuy
Posted: 14 Oct 2024 at 1:58pm |
Fred in Pa
Thanks(1)
Posted: 14 Oct 2024 at 2:33pm |
My machine shop resurfaces the clutch surface ,then mounts in a Lathe and cuts the recess .
I just wanted you to post a picture of recess so those who never seen this type flywheel clutch set up can understand it's not like most 2 step flywheels.
BrianC
Joined: 16 Jun 2011 Location: New York Points: 1619 |
Posted: 14 Oct 2024 at 3:50pm |
Ok, I will ask, why is it designed this way? What does the outermost step up do, other than get in the way?
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3952 |
Posted: 14 Oct 2024 at 9:53pm |
got to have weight to make torque
ekjdm14
Joined: 20 Aug 2024 Location: Alsager UK Points: 987 |
Posted: 15 Oct 2024 at 8:52am |
Next (possibly stupid) question incoming. Why the step down for the pressure plate mounting surface? Surely would be more cost effective both in initial manufacture & in subsequent repairs to have it level with the friction surface & have the pressure plate mounting surface .175" less proud of it's friction surface?
Edited by ekjdm14 - 15 Oct 2024 at 8:53am |
Fred in Pa
Posted: 16 Oct 2024 at 6:45am |
Having any luck on flywheel getting anyone to do it .
CleaningGuy
Posted: 16 Oct 2024 at 12:45pm |
Yeah ended up getting taken care of. The shop said they'd mount it in a lathe to get the step right.
Fred in Pa
Posted: 16 Oct 2024 at 1:37pm |
As I said above been getting them done for years that way . Any good machine shop would know how to do them .
