Cam question
allispuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Topic: Cam question
    Posted: 21 Mar 2017 at 10:16am
I think I may know the answer but is there any difference in the camshaft between the M Z and V code G226 engines?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2017 at 12:21pm
Maybe. Maybe not. The 175 tractor engine is the only engine that has a different camshaft grind. The "V" engine code means 8.2 or 8.25 to 1 compression, which could mean an LPGas engine in a D-17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2017 at 5:24pm
Ok so if on the side of the block it has 17- xxxx V for the serial number it has the grind of a standard D17 correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2017 at 5:49pm
That would be my guess. That is a D-17 LPGas engine, not a 175 engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2017 at 5:50pm
That is what I was thinking but I wanted to check. Thanks for your help
