Calling all welders here,,,,,, |
Page 12> |
| Author | ||
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35666 |
Topic: Calling all welders here,,,,,,Posted: 18 Jul 2019 at 2:41pm |
One other IMPORTANT point of Wire Welding, is it HAS to be PRISTINE Clean, no Mill finish, no rust, no coatings or paint, SHINY, CLEAN and NO OIL. Every one of those mentioned will cause a cut out sputter and inclusion in the weld.
| Sponsored Links | ||
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Posted: 18 Jul 2019 at 8:42am |
Well,,,Jay,,put it this way,,,that one was on the tractor when I drug it out the weeds to get it home,,,, I did add a tack weld as the top part kept wantin to fall off. When I build something,,I build it to last,,,ME,
![]() Edited by desertjoe - 18 Jul 2019 at 8:43am |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25247 |
Posted: 18 Jul 2019 at 6:06am |
Hay DJ Is that a factory or 'DJ special' fill/vent cap for the steering bolster? yeesh, Grade 8 bolts to attach the adapter ! Kinda 'overkill'.......lol Jay |
desertjoe
Posted: 18 Jul 2019 at 2:56am |
Hey JC,,,I woluld tend to say,,you gots you some pretty good service outa them tractor parts,,,,,but,,,but,, they can ALL be fixed. AND was I to have me a great reliable welder,,,,,I could,,,,,,,UMMmmmm Don't know if you remember,, way back when I was in the rebuilding of the D14 Industrial, I had a similar dilema of high priced parts with low amount of dollars. The splines of drive shaft and the hub for the front pump had wore each other out and cost of the shaft and hub was gonna be lots of dollars,,,so my engineerin mind went to work and I come up on a fix that still looks and operates like the day I done it,,,,, ![]() What I done was while in O'relly's,,I seen what was a 1" drive impact socket and a i" drive impact extension,,,,, The both pieces were only $20 and the socket was almost an exact fit in the center of the hub where the wore out splines were,,,,,
SO, I machined the center of the hub out to where the female part of the impact socket would fit in there just so,,,and put one of my "special" super duper welds on it to last forever,,!! I had a piece of 1" reciprocating pump shaft that was just the length of the needed shaft,,so I welded the male end of the impact extension to the driveshaft and PRESTO a drive shaft and hub arrangement that will outlive me and two-three others. The impact socket and extension are work hardened to outlive all that pounding back and forth so I feel sure they will work out just fine.![]() Edited by desertjoe - 18 Jul 2019 at 3:00am |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34617 |
Posted: 18 Jul 2019 at 12:05am |
Ol' Desert Joe with all the free advice here will be such a pro that he will be able to weld juss about everything... I gots some parts that need welding on my old 1327 discbine. Here's a picture of the drive assembly to the discbine's cutter bar... ![]() The drive hubs, there are three and this one pictured is the worse with worn splines... $90 bucks each... then the drive shaft, some worn splines, JD price on it is $136 bucks... and then there's the hexagon drive pucks with the 6 holes in them, They are $146 dollars and 4 cents... 4 cents? Yup, thats what the feller said, JD's that proud of them rubber pucks. Well anyways, with all the good advice on how to weld things, ole Joe will be an xpurt in welding these rubber hexagon pucks... I 'll get them in the mail to you a couple dayz after tomorrow Joe... an when your finished with them, I expect them to look like brand spankin new... ![]() Say, does anyone know what size of a hockey puck disc BMW uses?
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 17 Jul 2019 at 11:04pm |
I bought a POW-CON inverter welder about 1990 - it's DC / reverse polarity for Stick , Wire Feed , and can TIG with it but scratch start .
A high low setting and dial in amp adjustable , stitch weld , spray arc or ? Wish it had high frequency but seems only thing lacking . (Thermal Arc bought them out) son has 2 Thero Arc welders - I also have a Miller 304 that will do SMAW, TIG, MIG - that unit I bought from shop I worked for when it closed - was close to $5,000 new with water cooled TIG torch . Bought it for $1 when I was clearing out building Problems with sputtering can also be bad liner or bad gun - the Pow-Con when i bought it had a 130 Amp rating on the gun and seems I overheated it enough that i had to replace liners regularly - finally bought a 200 A gun - not as flexible but no more problems with bad liners . Also check your feed rollers as they can be worn and skipping on wire , also a wiper on wire where it enters the liner keeps both wire and liner as well as tips in good working order . |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4070 |
Posted: 17 Jul 2019 at 10:13pm |
i did not read many post but i would stay with lincoln or miller because repair parts consumables and acessorys are readly avalable
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3980 |
Posted: 15 Jul 2019 at 9:29am |
Your weld metal is being contaminated by picking up zinc from the galvanized pipe and you won't get a nice bead with the contamination.
desertjoe
Posted: 15 Jul 2019 at 5:19am |
One other thing,,,,, ![]() I did notice that when weldin on the galvanized tubing,,the welds will NOT be nice and smooth and tend to require too much grindin to make em look purdy,,,,I remember way back when,,reading bout weldin on galvanized pipe releases some gas that is hazardous if you are standin right over the fumes,,, I'm wonderin if this release of fumes are what are makin the weld look crappy,,?? This CH mig NOW lays a real purdy bead on carbon steel but looks like Chit on the galvanized pipe,,,,???
desertjoe
Posted: 15 Jul 2019 at 4:42am |
Hey Steve,,,,you know,,I've been told two different things on setting wire tension,,,,The CH tech told me to tighten the agjustin knob down to where it will NOT slip,,,,then a half more turn,,,?? Then a dude on YouTube had a long winded video that says to hold the torch end against a solid something, hit the trigger and adjust the knob to where it will slip when held up to something solid,,,,,UMMmm,,,which is which,,,???
Joined: 11 Sep 2009 Location: illinois Points: 90800 |
Posted: 14 Jul 2019 at 9:43pm |
If you have CERTIFIED Welders welding up a boiler or pipe line, you have to keep RECORDS, and the ROD has to have a paper trail of where it came from, what and who made it, and what % metals are included in the rod ( wire)... that is its CERTIFICATION.
Posted: 14 Jul 2019 at 9:41pm |
If it welds for a little bit, then SKIPS, it is probably in the roller adjustment ( tension) or the liner is getting OLD and grabbing the wire........... either way, not SMOOTH TRAVEL.
desertjoe
Posted: 14 Jul 2019 at 7:15am |
Well, Gents,,I gots a bit of an update as I did take all the comments to heart,,,, I had been buying the solid wire from Harbor Freight thinkin it was chea,,,,err,,, more economical,,so I went to the weldin supply and asked for their best (almost choked on thet word) wire they had and he handed me a roll that was ,,gulp,,priced less than a five spot,,told him again I wanted the best and he tells me that one is made by a company that only sells welding supplies and they have been carryin this brand for over 10 years with NO Complaints from any of the welders. Run home and took the gun apart again and cleaned it all out, blew the new liner out good,,reassembled it all and give it a go,,,,,Same friggin thing,,!! Messed with the wire speed a bunch and finally remember that CH tech had got me to reverse the leads (?) back couple of months ago, so I reverse them like manual says they should be and ,,,,,,,PRESTO,,,the sound of fryin bacon starts comin outa thet thing,,,!! It still erratic but I keep messin with the wire speed and finally get to where it will weld good bout a 1 1/2" long weld,,spit a little and then take off again fryin bacon, Lots more better if you just go for 1" welds,,, stop for an instant,,,then give her another inch,,,,, It hard to believe the changing to a different (better) wire has done the trick on this machine but I have still made up my mind to get me a 220 volt Miller soon as I find one worth the money. I don't want to mess with this CH so I can sell it while it still weldin good soon as I can. I cannot remember the brand of the wire I think,,Weld Cote,,?? but had a strip of brown paper coverin the wire with a tag "Qualified",,,??? qualified for what?? ![]() What other "GOOD" brands of wire are there out there?
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Posted: 13 Jul 2019 at 8:48am |
I don’t know on the value but I traded a Lincoln weldonpower 200
Rope start AC only for a $ 750.00 Ruger. It wasn’t near the welder you have. I’d really search out a Mm 200. They quit making them and soon the welders all started complaining so they made the MillerMatic Vintage which is what I have. It’s awesome but still not the welder the original 200 is. If you can test a capacitor or change out an electric motor you can make a MM 200 last forever. No boards or BS to mess with and the most crisp arm of all Migs |
desertjoe
Posted: 13 Jul 2019 at 8:13am |
Dang,,but you gots you a dang good memory,,THad,,I kept thinkin on thet welder so I had to go take a look see and you are exactly right it an AEA 200LE and still looks like i left it,,,what,,2-3 years,,??
I'ma gonna move a bunch of chit to get it out,,check the engine and get it runnin. One of the ta'ars is blown so got to fix that and put it on the MarketPlace for sale or trade for a 220 volt Miller mig. What you think a good sellin price for this "vintage" welder,,,,,, Ordinarily,,,,I dislike that word when I'm buyin,,,,,but,,,,?? I did find a brand new faceplate,,,looks nice,,,huh? |
Thad in AR.
Posted: 13 Jul 2019 at 5:49am |
Miller Aead 200 LE and apparently you use it as much as I use mine.
I have used it for a generator but that’s been a few years back. Edited by Thad in AR. - 13 Jul 2019 at 5:59am |
desertjoe
Posted: 13 Jul 2019 at 4:31am |
Yeah,,JC,,10-4 on keeping the flyin stuff away from them welders,,,I use up a lot of grinder wheels for most of my work and will NOT grind any metal around the mig,, I ought to have a canvas cover or something but usually either move the work or the welder away from the other to save the welder. I have one of those white plastic "trays" out of an old fridge that I use to cover the welder with when it stays out that works pretty good. I've bout decided I'm gonna have to get me a good 220 mig with a 50' power cord since I use a welder so much any more. I just remembered something when this all started with the CH mig,,,that I had rebuilt a miller arc welder with a Onan engine on a nice trailer sometime back and it been in the boat shed all this time,,,I should bring it out, dust it off and try to trade it for something I can use,,, I cannot remember which model it was,,but I bet ole Thad remembers,,,he helped me so much on it,
I'ma go look when sun-up....![]() |
DMiller
Posted: 12 Jul 2019 at 8:22pm |
For my stick rods I actually bought two old heated rod totes, fill one with what I intend to use, plug it in overnight and nice and dry by morning. Otherwise they lay in the tin I buy them in inside the shop.
TDF
Joined: 22 Oct 2015 Location: Seward, NE Points: 63 |
Posted: 12 Jul 2019 at 6:23pm |
Amen to that. Look for them on local auctions, and local classifieds. They regularly turn up in my area for under 1k. I got mine on a farm sale. Not much use. Full bottle of gas and full spool of wire for $750, a year and a half ago. And it is one fine welding S.O.B. capable of small welds up to very thick stuff. We haven't used the old arc since I bought the 200, and I built a fork attachment for a loader tractor that I've since used to pick up cars with and haven't broken a weld yet. TDF |
Leop
Joined: 03 Dec 2018 Location: California Points: 161 |
Posted: 12 Jul 2019 at 12:12pm |
Thats a great idea. I am going to start storing my wire in an 9ld fridge first thing after work today. I am thinking that I might add a light bulb like the gun safes do. Not needed for mig wire, but might help with the coating on my sticks not getting soggy? Thabks for sharing. |
JC-WI
Posted: 12 Jul 2019 at 10:21am |
the wire I sent Joe was baling wire...now ain't that funny that he would even try? I told ya'll he was CHEAP! LOL (poke,poke)
" Joe, did ye measure Shameless's balin wire he sents you??? if he sent the good stuff it would measure about 14 1/2 gauge, or... .076 ' an your little sputter prolly takes .030" ... What did ye do to get shameless's wire through that little tip on your welder? An if he sent ye some really cheap 16 gauge baling wire, it's still .0675" ... meaning you had to drill that tip out. LOL Say Joe, didn't you get Shameless's double platinum guarentee that if it didn't work, he would refund your money for twice what you paid for it? Worked in a peat processing plant where the dust would get into the welder contactors on the circuit board and after a few replacements of the little switch modules on the board of the 220v Lincoln wire feed, I started taking them apart and cleaning the points and then taping the seams shut to keep the dust out. You would not have believed how that dust could somehow get in there, but it did. One of the contactors would not even allow the spool to feed, another one messed with the wire feed and have poor splatter sounds... also the tips would wear out fast up there and had to change them out every couple days, we even used the dip to try and keep the sl*g from sticking. The dust probably came from getting on the wire at the feed rollers. We also had to lay the shielded cable out as straight as possible too. A new whip helped for awhile and still had to blow that out too.
desertjoe
Posted: 12 Jul 2019 at 8:37am |
CHIT,,,Shameless,,,,Ya got me on thet one,,,,, ![]() ![]() ![]() BALING WIRE,,,????,,what the heck I gonna do with all them rolls of baling wire you sold me as mig wire,,,???
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 12 Jul 2019 at 8:35am |
Many years ago I bought a new Lincoln 140. Which is 120 volt, because I figured it would be easier to use an extension cord.
Well that don't work, the wilder pulls a little over 20 amps when turned full up. I had used #10 romex and 20 amp outlets with 20 amp breakers, when I built my new shop. Because of this weldor I had to go to a 25 amp breaker. Never have used an extension cord with the welder. What seems strange to me is the welder came with a 15 amp cord cap. This set-up does work well. Dusty
shameless dude
Posted: 12 Jul 2019 at 8:16am |
I always used an old refridgerator to store wire and sticks in when between welds of anything. worked great keeping moisture out/off items stored inside.
DMiller
Posted: 12 Jul 2019 at 7:55am |
MIG gun tips and cones are considered Consumables, as they age they also corrode or develop burn markings internally as externally as that is where the wire receives its energy, I replace mine roughly twice a year low use, sometimes in hard use twice a week. I use a good quality Spatter Shield on the cones comes in a dip tub just poke the gun in it to minimize spatter build up collection.
shameless dude
Posted: 12 Jul 2019 at 7:50am |
Thad in AR.
Posted: 12 Jul 2019 at 6:20am |
II’m lucky if I use 1 or 2 small rolls a year. I agree small rolls now. Joe also make sure your tips will slide over the wire easily. I check mine and use a tip cleaner as necessary. I once had problems similar to what you describe. Wire would get tight in tip in spots. |
DMiller
Posted: 12 Jul 2019 at 6:19am |
Hey joe, increase that wire speed and turn UP the heat, that sputter is from losing contact or continuity and may be from too LOW a voltage setting. In that consideration you get a shield effect from the wire you just put down. Get some scrap 1/8" sheet stock and keep ramping UP the heat until you get a burn thru then back down. Seen it all too often and I use a Miller 210 that was performing similarly until a buddy of mine came over and did what I just explained. Zig Zag stitch, start at one side of seam, cross to other and pause JUST MOMENTARILY then sweep back, try it you will like it.
I still use stick for strength welds, 7018 rod. As for pretty and limited spatter/sl*g, MIG. |
Leop
Posted: 12 Jul 2019 at 5:32am |
My wire got a touch rusty once and caused havoc. The clearance through the tip is tight, and the rust just made the wire too fat. I had to throw the entire roll away. Now i buy small spools in case it happens again. |
Leop
Posted: 12 Jul 2019 at 5:23am |
Thanks for kind words Desert Joe. Im no professional weldor, and I don't design welders, but a lot of this is just common sense and an understanding of how companies make money these days.
Check out my last post. Yes, your torch head cost Campbell $4.00 or less. Feed roller mechanism - maybe $9.00. Entire welder in the box and shipped to Home Depot, $65 max! Those are cheap prices, and longevity will reflect them. Sad but true. Good luck on finding a boat anchor if you go that way. And if you pick a switcher that aint so bad neither. Just more cash short term and long term. Cheers to you. |
Page 12> |
