Calcium Chloride
Message Reverse Sort Order
FredinInd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredinInd Quote  Post ReplyReply Direct Link To This Post Topic: Calcium Chloride
    Posted: 23 Feb 2011 at 8:44am
I drove a concrete delivery truck for 32 yrs. In the winter, we had to add cacl to the load sometimes to speed up the setting times. You might go to your local delivery plant and ask if they would sell you a few gals. Our cacl holding tank had a capacity of 2500 gal. So when someone wanted 40 or 50 gals, they sold it to them at a decent cost. Just take a 55 gal plastic drum in the back  of your pickup. Just a thought......but wheel weights are alot easier on rims and tubes, cleaner too..
Edited by FredinInd - 23 Feb 2011 at 8:51am
Oh well, I won't do that again!
Italy Hill Produce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 6:53am
Matt and Don, What I read, back in 2000 was that lb per lb the solid weights gave you better traction because it allows the rubber to flex better and squat out giving you a larger foot print with less compaction per lb, Thus giving you better traction, OR conversly allowing you to add more weight with equal comaction.
The amount of power needed, would only matter when first getting the wheels moving.. if your tractor can't turn it's wheel weights I think you probably have other things to worry about :) I really think the difference in inertia is insignificant, for that matter in theory the solid weights would also help you keep going better when you hit a wet spot etc. (again probably not significant)
I think Calcium can be used, but it is mugh higher maintenance in the long run, and everytime you get a flat, if you aren't quick, you have to buy more.. Weights require no special pumps etc...
G tractor and an All Crop 66
Also Kubota MX5100F and M9540HD12
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 6:36am
Originally posted by Italy Hill Produce Italy Hill Produce wrote:
Another thing to consider, pound for pound, solid weights mounted on the rim, or on the tractor give you more traction than filled tires.. though if you have a loader you might want both ;)
With the weight on the rim instead of in the tire, you get a better tire print.. It is also better for the tubes/rims etc. and it is a one time expenditure...
We are working on switching our old farm tractors over to wheel weights, even though my dad has been running calcium in the tires since the 70's... Our old tractors are getting to the point where when they need tires, the rims are pretty shot too... If we switch over to pie weights the tires and rims will last longer...
Jonathan
We always had better luck traction wise with chloride.
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 6:33am
Been Using chloride in our farm tires for years, no rotten rims. Alot of rims have been lost to chloride, not to the fault of chloride, but to the fault of the farmer for not cleaning the rim when there was a leak. Chloride will not harm rubber(tire or tube), so if there is a rotten rim it means you have a hole in the tube, clean it up and you wont have a problem. Cleaning it up doesnt mean spraying it off with a hose, it means removing the tire completely, scrubbing the rim with warm soapy water and a brush, the reinstalling the tire with the proper tube......when I say proper tube I mean a 4-6 heavy duty tube, not a cheap 20 dollar 2 ply.
Cloride is heavier per gallon then antifreeze, washer fluid, beet juice or any other liquid for that matter, thats one of the reasons we use it, it has a high saturation point
1968 D15D,1962 D19D
Tricky Dickie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tricky Dickie Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 6:24am
I wouldn't touch calcium chloride with a bargepole! It is foul stuff which eats wheel rims and any other steel it touches. If you really want to use water ballast and protect your tyres from damage if it freezes, simply add 5 gallons of ordinary ethylene glycol radiator antifreeze to the tyre before you pump in the water. This will work forever and the worst that can happen is that in ultra-cold weather, the ballast will turn to slush which will cause no damage at all to the tyre, tube or anything else. Chuck the CaCl in the garbage can where it belongs!
Tricky Dickie
Edited by Tricky Dickie - 23 Feb 2011 at 6:26am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 12:09am
Where I lived, well water had more iron than lime. I don't know what was in the tires, but it penetrated the silver paint on my MF-135 and rusted it it minutes. I had it pumped out and I didn't put it back.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 10:39pm
Gerald, It sounds like somebody used some high iron water to mix for your tires. Flash rust can be caused by the iron particles in the water. I doubt it would happen to any surface that had decent paint on it, unless the flash formed on top of the paint.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 10:00pm
I am not scared to use Calcium cloride in the tires. Yes you do have to pay a little attention to them. it takes YEARS for the fluid to rust the rim. as far as Gerald's condition I would double check what you have inside your tires? the stuff does not rust instantly it takes some time.
There were tests done back in the day that prove you get better traction with fluid in the tires VS cast iron weights of equal weight. It also requires more power to lug around the weights on the rim, plus the weight of the fluid is put directly on the foot print of the tire and not in the center of the rim like weights.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 9:47pm
tucker is the one i agree with,i have used prestone in all my tractor tires with no problems.napa sells an adapter for this procedure
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 7:05am
Jonathan
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 6:45am
I use an old gear pump that I put on the tractor pto to pump the liquid in and out of the tube. It was used on a field sprayer and I put pipe to garden hose fittings on the pump and just switch the hoses on the pump to reverse the flow. Rinse the pump out with water and put oil in it when it is dry and you won't have a rust problem. I also put extra wheel weights on the tractors instead of calcium and water, no rust!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 11:00pm
Wash it off? How fast? My tractor rusted in a minute or two after it was sprayed with CaCl from a pinched tube in a split in the tire side wall. Didn't take hours or days.
Gerald J.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 9:09pm
I use Propylene Glycol... RV Anti-freeze.  I visit the local marinas about a week or so after they've stopped winterizing boats... they usually have a pallet or two in 1-gallon bottles leftover, and I buy it for a few pennies over cost.
Propylene Glycol is non-toxic, so if you spill it, or puncture a tire, you won't poison children, farm animals or toxically contaminate your fields and well.  Not as heavy as some things, but it'll do the job nicely.
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 7:56pm
Thanks Ted,
If I ever find it I'll post it.
Danny
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 7:32pm
Danny, the only thing that I could find for you is this:
http://www.jamesriverequipment.com/details/Agriculture/7730-Tractor
Doesn't help much though...
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 7:31pm
You get more CaCl2 per pound added if you use Peladow instead of Dowflake.  OxyChem formerly Dow makes a 90% and a 94%  CaCl2 pellet flake is only 77%-80% CaCl2.   The 94% pellet is smaller diameter and the most dissolvable. The 94% pellet is made with the intent the that the end user will be dissolving it. If CalCl2 is promptly washed off with luke warm water corrosion is not a issue.  Another bonus is the Dowflake and Peladow are American made.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 4:32pm
I have searched the web for about an hour looking for a rear tire weight system.  It mounted inside the rim and gave you weight without fluid.  Has anyone seen this product?
Danny
Danny Raddatz
Sheridan-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheridan-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 4:25pm
We installled winshield fluid with a swamp coolor pump.  It worked very good and is quiet cheap . A pump is less than $10 dollars, winshield fluid is about $1.50 a gallon.
HANSEN'S OLD ORANGE IRON
We show, pull, & go!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 4:13pm
I should add that if you reuse the old stuff you won't know for sure how concentrated it is.  If you pump it out split it between two 55 gallon barrels (one for each tire).  Then add more water to each barrel to match the chart for your tire size.  Add equal amounts of CaCl flake to each barrel and wait for it to dissolve.   Start with about half the recommended amount of flakes and see how it does.    If the flakes pile up on the bottom and don't dissolve you've reached the max saturation point.   If you reuse your old stuff and it was the correct concentration about half of the amount should work out about right anyway.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 4:06pm
I couldn't stand all the damage from fluid in tires, so I removed all fluid. Bought all new tubes, aired up and started buying weights. I got twelve plus tractors and did them all. Never been sorry, now I can sleep at night. LOL
Kurzy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 4:00pm
The old cacl works. It doesn't age, just has to be pumped out and a tire dealer used to handling it has the tool for that. My MF tractor manual mentioned how much CaCl it could hold and how much weight that added and farm tire handbooks like on line from Titan, Firestone, and Goodyear have tables of that.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 4:00pm
Ted - you can reuse the old stuff if you like.  As far as how much here's a chart:
http://www.firestoneag.com/tiredata/info/info_hydro_2.asp
Big thing is to replace the entire valve core's every two years.  That pretty much eliminates any issues with leaking.   Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 3:49pm
My tires are 14.9 x 28's.  Is there a way to calculate the amount?  Should I re-use the cacl that is in one of the tires?  I don't know how old it is?  The other rear tire doesn't have any in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 3:28pm
Called Dow Flake around here. The chemical reaction it gives off as its being dissolved in water makes it heat up.
Edited by DonDittmar - 21 Feb 2011 at 3:29pm
1968 D15D,1962 D19D
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 2:11pm
You can load your tires without apump. Mount a barrel on a stand so the outlet is higher than the tire valve stem get a adpt. [hose to valve stem ] tractor supply has them.  Put a valve on the barrel set the tire valve stem at 10 or 2 oclock  with no weight or air on tire , mix 5 lbs. cal - clor. to agal. of water, hook a hose  to the adpt. & barrel turn on will fill tire & burp its self, will take a few hrs. to fill. Ask tire man how much your size takes [ 11-2 - 24 takes 20 gals ]
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 1:46pm
TSC has an install kit $10 to $15 bucks.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 1:29pm
Ted,  If you were further south - like AK, South MO, TX, and the like - you could use a few handfulls of table salt.  That would keep the entire tire from freezing and if it did you could break it by hitting the side with a crowbar.
We had a fellow who worked for us from TexArcanna(?) AK and that's what he used in Fords.  Worked well.  However, WI is too far north and far too cold .
Good Luck!
Bill Long
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 1:01pm
I priced swapping my tires to some better WD wheels.  Mine are loaded with CaCl.  The tire dealer would take my dispose of my CaCl, but if I wanted something different installed, that was up to me to have available for them to install.  I think without anything other than CaCl, it was almost $300 per tire to hire the swap!
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 12:31pm
For a cheap way, go to your local auto repair shop and collect used antifreeze. Pump it in and forget about it.
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 12:13pm
we use magnesium chloride. It comes in flakes and you just mix it up.
Don't know where the farm gets it from but this is what it is.....two bags to a tire I believe for the Farmall M sized.
http://www.meltsnow.com/products-dry-magnesium-chloride.htm
