CA rocker arm torque spec
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: CA rocker arm torque spec
    Posted: 17 Dec 2017 at 9:07am
What is the torque spec for a CA rocker arm assembly?  The four nuts holding the  pedestals to the head.  Thanks, Tim
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2017 at 9:47am
I have always assumed the studs are grade 5 and torqued around 20 foot pounds or slightly more. I have a box of the aluminum stands that were broken/cracked that I also assumed they were over tightened because of how they were cracked. Torque standards for a 3/8" grade five bolt is 25 foot pounds. I have not found any of the stamped steel stands broken.
Edited by Dick L - 17 Dec 2017 at 9:55am
