CA Reverse Gears
JS1455v View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JS1455v Quote  Post ReplyReply Direct Link To This Post Topic: CA Reverse Gears
    Posted: 16 May 2019 at 5:54pm
Needing a little help on my 1958 CA transmission. I replaced all 3 reverse gears because they we worn and it was apart. Checked the inside and outside teeth before installing, but never thought to check the thickness. I could not get any gears to mesh up. Took it back apart and found the pinion reverse gear is ~.180” thicker than the old gear. Book shows 2 different part #’s for early and later. Never see more than 1 listed on parts websites. Thanks for the help.
uploads/14446/fullsizeoutput_452.jpeg
This page was generated in 0.215 seconds.
