CA lift valve?
Nat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nat Quote  Post ReplyReply Direct Link To This Post Topic: CA lift valve?
    Posted: 14 Jun 2010 at 12:01pm
 I have a question on a CA Lift. If you are looking from the back at the valve the seal where the lift handle goes thru is leaking badly. Does anyone make the seal or does anyone have one they want to sell? thanks, Nat
Nat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2010 at 8:57pm
 Thought maybe I ask a different way. The seal in question is on the left side of the valve boby if looking from the rear. The walve shaft goes thru the body of the valve and the left end of the shaft is where the leak is. Anyone got any answers? Thanks, nat
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2010 at 9:09pm
I've rebuilt a couple of those Valves. Sandy lake has the kit but if I remember right its mostly O-rings. Take it apart on a clean table and maybe the o-ring in question will just be hardware run.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2010 at 9:35am
Sandy Lake Implement has the seals  888-252-0656
Nat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nat Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2010 at 8:01pm
Thanks, I pressure washed it today and can now see the seal, and yes it is an o-ring.
 I've had a bunch of AC's over the years, but really like this CA. it starts and runs like a new one, but does smoke when first started, probably needs valve seals. I bought it with a SC blade and the origional 2 bottom plaw. I still has all the Snap Coupler on it and it works well. Pics to come later, Thanks, Nat
This page was generated in 0.101 seconds.
