CA hydro's dangit. |
akmarty
Joined: 11 Sep 2009 Location: Talkeetna AK. Points: 114 |
Topic: CA hydro's dangit.Posted: 15 Apr 2010 at 11:52am |
My 52 CA runs great I just don't get to use enough.My problem is the lift,I can't seem to find the spot that the lift will stop raising.just repainted seat from damage 3rd link did to it.Is there some adjustment I'm missing or is it internal? it will almost stop but still creeps up or down slowly,seems to work fine otherwise,plenty of lift power.3 days ago it got me in the lower back and dented up the seat real bad.Any ideas what is wrong?
thanks Marty |
CTuckerNWIL
Posted: 15 Apr 2010 at 1:17pm |
If the 3 pt is set up right you should be able to raise it all the way up without hitting anything. There is a hold position valve that should hold it part way unless it is not working properly, which sounds like the case. It sounds like the top link bracket is not positioned properly to allow full lift without hitting the seat.
akmarty
Posted: 15 Apr 2010 at 8:43pm |
Thanks Charlie I'll check that.
