CA Hydraulic Pump Capacity Question
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Hydraulic Pump Capacity Question
    Posted: 25 Sep 2023 at 9:29am
The CA hydraulic pump appears to have two separate 3/8 inch output ports.  I assume that one of the ports has an additional "delay" circuit for when the left cylinder is applied to for example the front cultivator while the right operates the rear cultivator.  I wonder whether the GPM throughput might be increased slightly by combining those two ports externally into a 1/2 inch line (thinking that flow capacity might be reduced slightly by the 3/8 inch line).
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 10:16am
Nope. It's only a 3 to maybe almost 4 GPM pump on a good day.
