ca hydralics
rilenz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilenz Quote  Post ReplyReply Direct Link To This Post Topic: ca hydralics
    Posted: 16 Oct 2024 at 11:40am
hope I put this in the right place now. Is it fairly easy to repack the hydralic cylinders on a CA. I like to do the work myself
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2024 at 1:56pm
pretty easy to do... after you get the packing nut loose ... just pull it apart.... have you tried just tightening the packing nut ?  that can work if seal is loose and not old / hard/ cracked.
Edited by steve(ill) - 16 Oct 2024 at 5:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2024 at 5:51pm
its going to look a lot like this...
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilenz Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2024 at 11:26am
Thanks Steve(ill) looks fairly easy. I'll look at the manual while doing the repair and give update when done.
This page was generated in 0.049 seconds.
