CA Hand Clutch Restore - Final Update 4/23
 Post Reply Post Reply Page  <123
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2026 at 10:22am
That is correct. What I’ve done in the past, with the clutch Assembled, is to totally collapse the springs and measure the gap in between the clutch disk and the pressure plates. Whatever that measurement is subtract 0.050” and that will be what you machine off.
Thanks & God Bless
Dennis
rilenz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilenz Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2026 at 5:12am
I will be tackling the switch over in the spring. So defiantly will be watching your progress. Do have a another ? I rebuilt my hand clutch this last spring and sometimes I hear a squeal when disengaged. Might be an adjustment thing ?
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2026 at 6:38am
I am just a rank beginner on the CA and learning as I go. We got this tractor last spring as a parts machine, Grandson got it running and putt-putted around with it last summer. It runs well but the main clutch is shot, the rear main leaks badly, and the brakes are toast.
The hand clutch was totally soaked in gear oil and was so well-lubricated that it didn't squeal at all Tongue Otherwise it functioned nicely and didn't slip, but we never really stressed it very much either. I only drove it a couple of times as Grandson had it commandeered most of the time Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2026 at 10:28am
Les,
Sounds like you need start at page one of my CA thread!:) your grandson will be very happy.
 Chris and Cheryl
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2026 at 2:00pm
  I have had my hand clutch apart a couple of time and the second time all I had to do was retighten the bolts that hold it on, I didn't use locktite on them and now it's slipping again. I am not planing on trearing it down again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2026 at 7:37pm
Les,
 Chris and Cheryl
I have followed your CA thread with great interest; you do set the bar rather high for we mere mortals Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilenz Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2026 at 6:32am
Thanks for all the insight I'll be moving the clutch handle this spring and will check all the parts. It works great just has a noise once and awhile. I think it would work much better on the left when operating the hydralic lever when using the back blade and loader
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2026 at 8:36am
I snapped more photos of measurements that may be worthy of consideration.
This is the spring cover sitting on three springs, when fully assembled there will be no gap. These are the spring cover ears that would need to be milled shorter in order to increase the spring's holding force.
This is a spring fully collapsed in a c-clamp; it would require a massive amount of milling before a stock spring would approach coil bind, but it is something to keep in mind.
CA13414 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 47 minutes ago at 6:10am
Awesome job it looks great! I agree, I would love to have moved the hand clutch to the left. To bad I didn't think of it when it was all apart and we repaired our hand clutch!!!
Dan
Edited by CA13414 - 2 hours 18 minutes ago at 6:39am
