CA engine overhaul question
Morgan in AR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morgan in AR Quote  Post ReplyReply Direct Link To This Post Topic: CA engine overhaul question
    Posted: 18 Mar 2016 at 8:28pm
Specifically about the bushing that the governor shaft rides in. The original one was split and had four notches in it, probably for oil. I ordered a new aftermarket one, and it is soild, with no notches. I had the block at the machine shop to have cam bearings installed, and this bushing. The machinist said that he thought the new bushing fit too loose, so I had him put the old one back in. I test fit the shaft and it seems tight now. What's the deal? How do you install them, and do I need to get one from agco. Thanks -Morgan
If we loose freedom here there is no place left to escape to. This is the last stand on earth. -Ronald Reagan
This page was generated in 0.104 seconds.
