CA Carb |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: CA CarbPosted: 15 Jun 2015 at 6:40am |
Thanks
The 844 was used on the D14/15 149 ci engines. I have used this carb on my B and it did help it a lot, but since the original B carb has a smaller inlet it was obvious it would. I did not realize the CA came with a larger carb (Zenith) originally. I just never compared the two.
Charlie
dgerth
Posted: 15 Jun 2015 at 5:43am |
Speaking from ignorance inre: the numbering sequences, I am running a TSX-853, larger?, on our CA currently with a 160 cid which runs very well. I tried it on the 125 cid and it also worked quite well. Just me tho.
dg
Posted: 14 Jun 2015 at 9:02pm |
If the TSX844 is from an engine that makes more rated HP than a "CA" does, it will probably make more HP on the "CA".
Charlie175
Posted: 14 Jun 2015 at 8:12pm |
Currently I have a stock Zenith 11142 but I also have a TSX-844.
I know the bolt pattern is wider on the TSX, both air inlet butterflies are marked 18. I didn't measure the venturi but they look close. I assume the TSX has a larger main jet? Would there be any advantage in using the TSX on my CA? Stock engine, running more RPM but limited to 3.5 mph |
Charlie
