CA brake spring and decal question
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Topic: CA brake spring and decal question
    Posted: 04 Apr 2010 at 9:24pm
Hello,
I just put new brakes on my CA, and for the brake spring I know the one end loops over the adjusting bolt, but does the other end hook around the square hole in the casting in front of the brake drum? And also, for a 1953 model, it would have the straight decal right? not one with the left side of the "A" in allis going down farther than the rest of the letters.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 6:47am
I have a set of CA Decals from Maple/Hunter Co I need to sell, let me know if interested,
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 7:21am
Yes the brake spring sticks threw and hooks on the slotted hole in the front  side of the brake housing Decals I am not sure on .
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 7:51am
Decals should be black with A and S the same size as the other letters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 2:53pm
Thanks
Larry in OK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 9:58pm
If you can get a helper, putting on the new spring is a pretty easy trick. I had an old heavy long screwdriver with a messed up tip. I cut a small slot in it and ran it through the spring and pushed the hook down to the slot. My helper then hooked the hook and pulled it into place.
This page was generated in 0.332 seconds.
