Ca 12v battery?( Cca?)
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Topic: Ca 12v battery?( Cca?)
    Posted: 08 May 2020 at 2:19pm
My model CA is converted to 12 volts and needs a new battery so what size battery is the best for this size motor and also that will fit in the battery compartment on a CA?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 2:22pm
I use a group 522 or sometimes call a group 22F (for Ford) it's about the same size as a 6 volt group 1. Don't let the battery place give you a standard group 22, it's too tall and skinnier.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 2:24pm
You will have to measure the size of your battery box and get a battery that will fit. I am asuming that it has been changed to negative ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 3:22pm
I left and did not measure the height of my battery box I only measured the length and width
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 3:23pm
It's 9 and 1/2 by 7 in
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 3:50pm
I use and sell the Deka 526MF Battery for the B,C,CA boxes. They fit in the box nice. Not to high so you can get the cables on. 665 CCA's @ 32 degrees. 540 CCA's @ O degrees.
HTH.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 4:41pm
Thanks the height of my battery that's in the tractor box now is about 6 in tall...
I was at my tractor supply company store and did not see anything close to what I have so I'll just have to wait until another day to get something that's a better fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 5:01pm
I think mine is a #26... The length is about 8 inches... 7 inches wide and 7.5 inches tall... I like the length to be  1.5 inches smaller than the battery box.. Makes it easier to get the + cable on without contacting the box walls. I have a small chunk of 2 x 4 that sets on one end to keep the battery + side away from the box. .......... the 9 inch batteries are TOO CLOSE.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 5:04pm
A lot depends on what you use your tractor for, but I have a "parade queen" that is only used for parades and shows in the summer. It's never started in the winter.
A friend of mine had a used lawn tractor battery that he gave me, that works ok for me.
I would hate to try to start it when it's 20 below, but it doesn't take much to start it in the summer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 5:23pm
Yes my battery that is about 9 in is way too tight in the box...
that's why I'm asking the requirements for it so that I can get a smaller battery that has good enough requirements...
last year as long as I kept a battery tender on it it would start up right away but lately it's been getting worse and worse and now only starts when jumped.
Thanks Matt 👍
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 3:08pm
BCI
Group
Size           Length     Width        Height
26             8 3/16     6 13/16     7 3/4
26R           8 3/16     6 13/16     7 3/4
The 26 is what I use also.  For ALL of the WD/WD45, B,C, CA tractors.
The 26R just has the - and + is switched to the other side, making it easier on some to hook up.  If I remember correctly, the 26R has the + closest to the right side of the box, close to the starter.  HTHs
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 6:33pm
The 526mf has a huge price variable (which doesn't make a whole lot of sense to me but some places have it for around $70 and others have it for nearly double that)
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 8:18pm
I have an IB and no good place for a battery box. I tried to hid a small one in front of the right foot, inside the frame rails... All i could get to fit was a 230 CCA lawn mower battery as  WF said... did that for 10 years.. Finally decided i want more a battery with a little more ass to it for winter start ( I plow snow).. so i bought a bigger  batter that is about 450- 500 amps or so  ( Smaller than the #26 )..... so it does not take a lot of CCA to start this motor.............. #26 is ideal for the battery box.
Trapdoor1873 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trapdoor1873 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2024 at 9:02pm
I bought a 22F from Interstate. Fit perfect and room for box cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2024 at 9:51pm
22F is extra LONG and extra TALL...... the #26 is a much better FIT.... a little clearance on all sides is a benefit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trapdoor1873 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2024 at 10:06pm
I had plenty of clearance for connecting cables and room for the top cover. Not saying you are wrong. Just saying the 22F worked good for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2024 at 6:43am
As I said in my first post : There are TWO different group 22 batteries. Why I have no Idea. One of them is a perfect fit for replacing a 6 volt group 1, the other is taller and skinner. A quality battery shop should have both, just be sure to get the short fat one.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2024 at 6:48am
The small cheap (like $60) battery Walmart sells fits my CA perfectly and will start it all Winter no problem.Measure and take your tape measure to Walmart.Its guaranteed 1 year but mine is over 3 years old
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2024 at 9:59am
thats what i bought.... about 4 years old now...
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2024 at 10:13am
Since quite a few of my tractors are "parade queens", they are never started in the winter. I've had really good luck with the inexpensive (=cheap) Walmart batteries. I've got some that have a few years on them with no problems. They are kept in the tractors in cold storage in the winter. I rotate a small automatic battery charger between them to keep them fully charged.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2024 at 11:15am
A Battery tender is a good investment for keeping Batteries "active". Summer or Wintertime for vehicles not used often. Keeps the sulfating down and adds longevity to the Battery's service life.
Steve@B&B
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2024 at 2:24pm
Ditto on the battery tender!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 1:51pm
I have solar charger on my bulding and just rotate them around when I am in the building, keep my batteries up all winter long.
