C hydraulic Cylinder?
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: C hydraulic Cylinder?
    Posted: 03 Apr 2016 at 8:56pm
How hard is it to repack the cylinder on a C?
Can't fix stupid
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2016 at 9:14pm
Unscrew the end slide the packing nut off the end. Pull he old pickings out put the new ones in and screw the packing nut back on. Soak the new packing so in oil before using them.ifi rember correctly there should be 4 leather chevron seals in it. If the Ramos in fairly good shape it'll take you about 30 minutes.one of the ones I did was so bent it would Bailey move. I straightened it on a hydraulic press till it rolled on a flat table and put back together. Since there are several seals even a lightly pitted ram will seal well.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2016 at 10:10pm
Ok. I'll give it a try then. Agco carry the seals?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2016 at 10:19pm
It's been quite a few years since I got seals for a c but I did get seals for a WD 45 two years ago and they were $14 a set.if you don't have a local AGCO dealer try sandy lake. They have been helpful in the past they got me a NLA part
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 1:22am
AJ there's a hydraulic place in Mexico that keeps all kinds of things like that to repair cylinders, jacks,and even make parts, and they are good. By the way I left a message for you earlier for a 45 rocker shaft if you have one. Thanks.  Leon R  Cmo
